Old 26-03-09, 09:56 AM   #11
Doofer
Default Re: Startup Error - What does it mean?
Fallen Angel - Yes, tested with the multimeter and compared to all the available specs it looks fine (I had reg/rec problems with the 400, so have had practise there)
Flymo - Thanks, I've already done that twice, but to be honest for a low mileage bike (16k in V plate 4k of which I've done since Nov) the poor thing is a bit of a state, it has been dropped and dented at some point in its life and a half-hearted attempt at repair was made, ie broken bits were preplaced, but scuffed, dented and bent bits were left if they were still functional. It also looks like its spend a lot of its time sweating under a cover, the paintwork doesn't suggest its been left outside long term, but corroded, green connector blocks and the like suggest damp has been a problem, I'm avoiding re-wiring connector blocks it I can help it, the idea being only fix it if its broke, but as I'm having one problem after another it's starting to look like a new loom of a complete rewire would be easier.
The poor thing is finally getting the loving care it deserves, but its a slow process as I hit a new problem every time I fix one. I could give up, but its not in my nature and despite a very rocky start I'm finally starting to get on well with the bike despite the probelms I'm having with it.
Doof
Old 26-03-09, 09:59 AM   #12
flymo
flymo's Avatar
I think you may have answered your original question though which is that dodgy wiring and connections is likely the cause of the rev counter behaving like it is.
FI error C42 frequently breakz187 SV Talk, Tuning & Tweaking 2 19-03-09 12:43 PM
groggy startup and lose of power with backfiring hbaden00 SV Talk, Tuning & Tweaking 2 19-06-07 08:09 PM
startup problem lokidragon SV Talk, Tuning & Tweaking 9 17-06-07 06:59 PM
Clunky Startup.. Daimo SV Talk, Tuning & Tweaking 8 29-01-07 03:06 PM
Clonking on startup Warthog Bikes - Talk & Issues 16 15-06-06 09:48 AM
