Old 27-05-09, 02:19 PM   #11
Holdup
Default Re: Siezed rear caliper?
If its seals i think ill pop to my local stealership 1st to see if they are in stock as i dont want too wait
Going to look at it now
Old 27-05-09, 09:41 PM   #12
Holdup
Took it off piston seemed to be moving freely so i just cleaned it up and left it in, cleaned all the sliders up they were a bit rough got it back in tightened up the rear 12mm caliper bolt and you guessed it, the 12mm bolt snapped... luckily the claiper still moved up and i got the snapped bit out with some pliers and then found a bolt from the fzr which fits but is only a temp replace untill i get a new one which should hopefully be friday, i think ill replace the other bolt as well just to be on the safe side.
rear brake pins siezed - what now ejohnh SV Talk, Tuning & Tweaking 31 15-12-08 01:16 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
How do I free a caliper that's siezed onto a disc? monkey SV Talk, Tuning & Tweaking 13 29-03-07 07:17 AM
rear caliper pad pin siezed mec SV Talk, Tuning & Tweaking 12 23-05-06 07:04 PM
