#11 |
Pop it into dealer mode and check.
Look here http://forums.sv650.org/showthread.p...eferrerid=7747 post 2 steps 9 and 10. |
#12 |
Sorry for being dim but how do you get to the fuses?
#13 |
Aren't the fuse box under the rear pillion seat? are on my curvy. either way it'd be there or by the battery AFAIK.
#14 |
Where the hell am I?
What bike you got mate, curvey or pointy?
No on your curvey they should be under the riders seat, near the battery iirc. Unless you had some work done and someone moved them of course. I know when i fitted my ZX6 shock to the bike i had to cut out the battery tray a bit and move stuff about.
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
#15 | |
If so, or if you diconnected the leads to the battery, it COULD be that you haven't screwed the terminals down enough. You switch on the bike, the lights come on, you then hit the starter - do the lights go off and is there a click from the area of the battery. If so then its a possible loose connection.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#16 |
Firstly I put it in dealer mode and it said -C00 which is a good sign
Its a pointy SK6 the battery is well and truely screwed to the terminals When trying to start it the only thing that happens is the light dims a bit? still none the wiser |
#17 |
Fuses all seem fine too.
When it fell over I had to change the gear selector pedel and the gear lever but they both seemed to go on fine! Any other ideas anyone? |
#18 |
fuel pump goes through the paces with the ignition is turned on.
I think it must be something to do with the clutch switch but I don't know how to check it. Is there any way that you can bypass the clutch switch? |
#19 |
if the spade connectors just pull out then just connect the 2 wires together m8.
#20 |
used my "dealer tool" piece of wire to connect the 2 spades, still nothing
I am gutted, really wanted to go out this weekend and cant afford the garage fees at the moment... poo |
bike wont start, help! | stanie | SV Talk, Tuning & Tweaking | 15 | 31-03-09 09:39 PM |
Bike Wont Start Need Some Help Lol! | sv650k4 | Bikes - Talk & Issues | 56 | 29-01-08 08:17 PM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
My bike wont start - why? | SV Ste | SV Talk, Tuning & Tweaking | 6 | 01-12-05 08:23 PM |
Bike wont start!! | Robbo_ | SV Talk, Tuning & Tweaking | 9 | 31-08-05 07:46 PM |
