Old 12-06-09, 10:15 AM   #11
zunkus
Default Re: Curvy not starting, faulty sidestand switch. Can it be bypassed?
Thanks, that's mighty nice. Diodes are mostly used as a sort of one way valve in dc circuits. A dc current passes through it one way but doesn't if the polarity is reversed. You can check a diode with an ohm meter, it gives an indication of a low resistance one way and zero resistance when reversing your test leads.
Old 12-06-09, 10:18 AM   #12
Spiderman
Where the hell am I?
Spiderman's Avatar
I'm a mighty nice guy. Sometimes.
And thanks for that edumacationum, always good to learn new thngs
Old 12-06-09, 11:28 AM   #13
joshmac
Originally Posted by zunkus View Post
Some info to anybody reading this.
You can eliminate half of the circuit fault-finding by actuating your starter solenoid by simply juicing the 12 volt sensor circuit on the starter solenoid. If that starts the bike you're left with clutch switch, fuses and small relay box found nearby the fusebox to check. If those components are ok check the harness.
If the bike starts ok whilst in neutral but stalls when you switch into gear then stand switch faulty.
No the sidestand switch is functioning as it should if it starts in neutral but stalls when you put in into gear if the stand's down. If the stand's up, however (which I'm guessing is what you mean come to think of it) and it stalls then that switch is a very likely culprit.
If your neutral light is not lighting in your dash then the bike won't start with the stand switch open.
(if the bulb's fine, yes)
A question.
The service manual says that there's a diode inside the stand switch. I don't know what this is for and can only guess that it's a protection for a reversed battery. Anyone know more?
Glad you've got it running again mate. So satisfying, I find, when you solve a problem
I'm not sure about the diode, but as you say, they are normally used for protection in the event of the current flowing in the wrong direction, so that would be my guess too.
Curvy Sidestand switch zunkus Stuff Wanted 0 10-06-09 07:21 PM
Right Switch Gear - Curvy Demonz Stuff Wanted 8 09-01-09 01:15 PM
Sidestand switch cable routing. Normski SV Talk, Tuning & Tweaking 4 01-02-07 06:07 PM
FRONT BRAKE SWITCH, 99 CURVY Well Oiled Stuff Wanted 1 07-06-06 01:10 PM
Help!!pic of sidestand switch needed dmc2373 SV Talk, Tuning & Tweaking 1 07-02-05 10:25 AM
