Old 09-07-09, 11:39 AM   #11
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Engine noise
Originally Posted by SUPERSTARDJ01 View Post
I should also add it's just over 15k on clock so could be tappets?
Oil sounds fine to me. I thiink its at 12,000 that you should have the service to check valve clearances so it may be worth doing that.
Old 09-07-09, 12:50 PM   #12
SUPERSTARDJ01
Originally Posted by sv_rory View Post
Where abouts in mk are you? a very good friend of mine is a bike mechanic so I could ask him to pop over for you and have a listen.
Beanhill for my sins
Old 11-07-09, 10:35 AM   #13
SUPERSTARDJ01
Well I went to 2 different garages and one said noisey water pump (ticking noise) and the other said no it's not it's your timimg chains.
Are these relativley simple to fix?
Old 11-07-09, 12:32 PM   #14
Alpinestarhero
Is the noise apparent at any particular revs? A timing chain noise will be persistant through the rev-range. You can "listen" to the timing chain by putting a screw-driver to the engine and putting your ear to the other end - if it is a timing chain, its probably likely to be only on one cylinder.
I think you need to get a third opinon from someone, and dont tell them what anyone else has said. SV engines are noisy and they do have ticks and rattles and stuff...it might be a suzuki thing, as the bandit i've been riding also has some odd noises
Old 11-07-09, 02:42 PM   #15
markmoto
checked chain and sprockets including front?
Old 11-07-09, 03:24 PM   #16
SUPERSTARDJ01
It had a service about 1200 miles ago and it's chain tightened by garage 1 week ago, chain and sprockets were all fine then.
The noise is a tickingish noise at low revs and throughout but sounds at 5000 rpm + like it's doing 9000+ rpm.
engine noise. cmc1 SV Talk, Tuning & Tweaking 24 12-06-08 11:32 AM
Engine Noise Torn-Thorax SV Talk, Tuning & Tweaking 1 02-12-06 07:56 AM
odd noise from engine weazelz SV Talk, Tuning & Tweaking 3 01-09-06 09:11 AM
Engine noise Sudoxe SV Talk, Tuning & Tweaking 6 10-07-05 10:25 PM
Engine noise SPeeeeDY Bikes - Talk & Issues 7 27-03-05 02:10 PM
