Old 06-08-09, 02:14 PM   #11
Spanner Man
Default Re: Ideas of what causing running issues.
Good afternoon.
Remove the HT caps & snip 1/4 of an inch off the HT lead, this should ensure that the caps screw into clean copper. If you have difficulty screwing them on, screw a tiny self tapper into the lead beforehand, this will provide a sort of thread for the HT caps to screw onto.
You can drain the carbs without removing them. Although it's a bit of a pain.
You'll need a long 5mm ball ended Allen key & a torch to see the drain screws. You access them from the right hand side of the bike, the front screw is located at behind some bracketry & is rather difficult to see, hence the need for a torch.
As your tank pipe was blocked it's highly likely that you have water in there, peep inside the tank, using the aforementioned torch. Water will appear as a 'Jellyfish' lurking at the bottom.
Cheers.
Spanner Man
Old 06-08-09, 04:49 PM   #12
Originally Posted by RobH13 View Post
the breather pipe at the end of the tank had been sealed of!, this was removed and dirty water ran out,
The main/only reason someone would do this is if the drain tube through the middle of the tank has rotted through. If you fill the tank now it's been unblocked, I reckon fuel will run out.
Old 06-08-09, 06:51 PM   #13
RobH13
Cheers Yorkie,
Put a bit in yesterday, about 1/2 a can. At what level would i start to leak fuel roughly ?
Rob.
Old 06-08-09, 10:30 PM   #14
That would depend where the pipe has rotted through.
Pop the tank off, blow into a pipe on the bottom of the drain (it's hidden underneath, just in front of the hinge). Put your finger on the top of it (next to the filler hole), you should be able to feel pressure. If no pressure, and the air you blow in is going into the tank, you haz this problem.
It would explain your running issues.
Old 07-08-09, 04:47 AM   #15
RobH13
Cheers YC,
Should have figured the pipe went from top to bottom , show my mechanical skills, mind i did state earlier i don't have any.
Thanks again
Rob.
Old 12-08-09, 09:18 PM   #16
RobH13
Just thought i would update on what was causing the running issue,
Well it appears that one of the carbs was over fueling and they both required a good clean. Was taken away this morning and stripped by a mate and then the carbs were balanced and everything now appears to be spot on.
His word's
" It pulls like a F***ing train"
Hehe, just hope all goes well tomorrow and i can take it for a run.
Rob.
Old 12-08-09, 10:22 PM   #17
So why did they seal the breather/drain? I would certainly check.
sv running problem? any ideas Crunchy SV Talk, Tuning & Tweaking 6 31-07-09 04:27 PM
OK, so what is causing this oddness? Running a bit funny. northwind SV Talk, Tuning & Tweaking 26 25-06-09 06:45 PM
SV650S K2 running issues jammin32 Bikes - Talk & Issues 11 16-12-08 08:03 PM
2000 SV650S - running issues hobsonr Bikes - Talk & Issues 9 29-05-08 01:20 AM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
