Old 07-10-09, 09:37 AM   #11
STRAMASHER
STRAMASHER's Avatar
Default Re: Fuel Injection or Carburetor?
FI everytime.
Just got a carb'ed bike again after 7 year without and it is a major pain in the azz to start. I have had years of pressing a button and going. Bit of a shock. Fuel taps and chokes. Antiquated.
...and they feel fluffy. Give me FI instant response everyday.
Old 08-10-09, 12:04 PM   #12
andreis
Ok, I haven't seen this posted yet, but FI has another advantage over carbs (correct me if I'm wrong). Fuel injected engines produce more bhp and consume less on a general note. (for example, same sv engine, but different carburation, as the situation goes), as in more efficient in general (not just emissions)
@GavinD: I was under the impression carbs where smoother with on/off moves then (slightly deprecated) FI
Old 08-10-09, 01:10 PM   #13
zsv650
having had both carb and fi sv's i prefer the fi feel's better.
Old 08-10-09, 01:14 PM   #14
Alpinestarhero
I dont mind my carb'd bike. FI makes cold starts a little easier, but really, whats so hard about pulling a choke lever?
As for carb icing, that only occurs in the first 10 mins. Once everything is up to temp, an SV wont suffer from it. I get annoyed, however, with the bike cutting out in the first 10 mins, so I use V-power fuel. It works out cheaper than silkolene pro FST (plus, I notice it improves the smoothness of throttle response from zero throttle to just a whiff of throttle)
Also, its easier when something goes wrong to fix 'em...because its all mechanical.
Old 08-10-09, 01:26 PM   #15
philbut
Fuel taps are nothing to do with carbs - you could have an FI bike with a tap, or equally (like the SV) a carbed bike with no manual fuel tap. Choke I'll give you though
Old 08-10-09, 01:42 PM   #16
GavinD
Thats what I thought - but experience delivered different feedback on same roads and conditions. Gearing was the same, tyres same, just felt snappier on the carby which made it look to my friends a little more ragged (not a bad thing as they were too scared to overtake!!)
Old 08-10-09, 02:23 PM   #17
I think you do not do the SV justice, mine has never cut out in the cold. That is a symptom of carbs being out of balance...
Old 08-10-09, 02:34 PM   #18
Alpinestarhero
...as they very much were
to be honest, it was only cutting out on days where there was alot of moisture in the air, misty days
Old 08-10-09, 02:35 PM   #19
So, "I didn't maintain my bike, and it went wrong" is hardly a design flaw of the carb is it
Old 08-10-09, 02:55 PM   #20
Alpinestarhero
as i said, it only happened on days when it was quite misty. Early in the morning it was a problem, but not later on
I'll do a test this winter with "standard" fuel, see how the bike runs on a misty morning with that now the carbs are doing their work properly - be interesting to see if I may still have a problem
Fuel Injection Light mayang SV Talk, Tuning & Tweaking 0 24-07-06 07:23 PM
fuel injection issue w1ll15 SV Talk, Tuning & Tweaking 5 18-07-06 05:02 PM
K6 Fuel injection Baph SV Talk, Tuning & Tweaking 4 12-07-06 10:41 AM
Is it possible to flood Fuel Injection? Scoobs Bikes - Talk & Issues 23 12-12-05 06:31 PM
Fuel Injection... steveo SV Talk, Tuning & Tweaking 6 23-11-04 01:43 PM
