Old 06-11-09, 10:12 AM   #11
jambo
jambo's Avatar
Default Re: Indicators - work with alarm but not by the switch.
I believe the alarm uses it's own fuse to flash the indis, I had the same symptoms and it was just the fuse.
Asteer, might be worth checking your wiring or the switchgear - but unless it's a big pain in the **** I'd just take it back to the garage to do.
Unless anyone can think of any connections they might have just left unplugged
Well if the hazards and the indicator switch do nothing then it'll be the first live connection up-wind of the indicators, but after the patch in for the alarm. The earth connections should be common to the alarm's system for flashing so should be fine. I'd be pretty confident there's a plug someone's forgotten to reattach.
I'd probably take it back to the garage, it's their mistake, and they should be able to put it right fairly swiftly, otherwise you'll be out there with a multimeter and a wiring diagram or just pulling tank & plastics looking for the disconnected plug.
Jambo
Old 06-11-09, 10:23 AM   #12
asteer17
Thanks for your help guys, im gonna take it back there later on, should be a quick problem to fix shouldnt it, want the bike for the weekend obviously lol
Old 06-11-09, 10:31 AM   #13
asteer17
no1 happens to know where these plug or plugs are do they?
Old 06-11-09, 10:52 AM   #14
Neeja
Don't take it back to the dealer - I can almost guarantee what the problem is.
I had the exact same problem about 2 months back. Take off the rider seat and pull out the fuse-box. Trace the wires from the indicator fuse down into the loom (you'll probably need to remove all the cable tidying stuff around it). There'll be a break somewhere down there - mine was about 4 inches into the black loom cover, and 30 seconds with a soldering iron and some electrical tape set me back to right.
Old 06-11-09, 11:19 AM   #15
asteer17
ok ill have a look but i only took the bike in to have the alternator changed and when i drove it away the indies werent working
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
tip off switch antony SV Talk, Tuning & Tweaking 16 16-10-08 05:22 PM
U-switch Ed Idle Banter 9 27-08-06 03:15 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
