Old 03-01-10, 10:19 PM   #11
speedplay
Default Re: Help needed - injured bird
2 buckets, both half filled with water.
Put the bird in the bottom one and place the second bucket into the one containing the bird.
Job done.
Old 04-01-10, 12:41 AM   #12
Sally
Rifle.
Old 04-01-10, 08:37 AM   #13
Von Teese
In reality the thing sounds like it was probably so far gone in shock that it didnt die a horrible painful death because it was likely to not even be aware of anything, adrenaline does a good numbing job.
However I do agree with the fact that something should not be left to suffer unnecessarily. (and Im an animal lover too, and still a qualified and registered Vet Nurse despite my main occupation)
(oh and Speedplay's bucket thing... I know he has thrown that in to evoke a negative response, but because no-one is biting I can say...simply dont use it - It is a cruel way to 'euthanase' anything that is even remotely aware of it's surroundings. The spade or brick method is even preferable to that)
Old 04-01-10, 08:44 AM   #14
speedplay
Er, no I didnt.
I have done it a number of times before and will do it again if I have to.
As you said, once its in shock, the chances are that It wont know whats happening anyway.
A couple of minutes at most and the bird will have drowned.
If you decide to use a spade or a brick you have to make sure that you kill it with the first blow.
One slight mis-aimed blow could leave it further injured, leaving it in further distress and also leaving you to finish the job off with another blow..
Old 04-01-10, 11:29 AM   #15
Von Teese
I disagree that this is humane, sorry but everything I know about Veterinary Science says that this is just wrong.
Misaimed brick...not likely for a small bird's head, quick and out of its misery.
I wouldnt like to drown, its a horrible death.
yummy bird arcdef Photos 9 03-05-09 09:26 PM
Scrubs up well for an old bird mister c Photos 7 14-04-09 06:32 AM
Bike vs Bird The Guru Bikes - Talk & Issues 13 18-03-09 10:59 AM
I hit a bird or something! Lucas Photos 43 24-12-08 08:07 PM
Bird Strike Ward8124 Idle Banter 17 07-04-06 04:32 PM
