Old 22-01-10, 05:23 PM   #11
johnnyrod
johnnyrod's Avatar
Default Re: Race tech emulators - fill rebound hole?
I'm using 15W but I weigh only 65kg nekkid. Probably 20W would be better. I would think having the rebound holes open would give you more consistent damping than relying on blow-by in which case you would expect more difference in damping betwen the two fork legs, which is bad of course.
Old 27-01-10, 12:39 PM   #12
Icanopit
Thanks to all for advise and observations. I have decided to make the changes progressively, start off with opening out the 4 damper rod holes and play about with oil rate and air gap (nothing drastic) and see if I find what suits me. Then IF needs dictate, close off the smaller holes (can always be redrilled) and again try oil's etc.
JOHN
Old 28-01-10, 12:40 PM   #13
Not really enough difference there to bother anything. There's a bleed hole in the emulator too IIRC
Old 28-01-10, 01:48 PM   #14
SV650Racer
We have always run 20w oil and never filled the damping holes in any of the minitwin forks we have prepped. Won plenty with them so they do work. Thats for the track though and hard use.
Old 08-02-10, 08:50 AM   #15
Icanopit
Not wanting to "hijack" another thread that's running, How to improve suspension? but a note on the lookalike emulators from the states. The alternative examples seem very good value but are rated for Harley's with a spring rate of 24 lbs/in as against the Racetech @ 64 lb/in SV, not sure whether the US ones are available with a better spring/valve rate.
Fortunately I purchased a set of R/tech off a fellow Orger at a simlar price as against from buying in from the States.
Just an observation for guidance.
JOHN
Old 08-02-10, 08:59 AM   #16
you mean the actual preload spring on the emulator?
Old 08-02-10, 09:16 AM   #17
Icanopit
Sorry YC, yes the emulator spring. Due to it's short length and already "tight" coils I guessed that there may not be enough left in the spring to get adequote increased compression to achieve much more?
JOHN
Old 08-02-10, 09:34 AM   #18
They are designed to pop off rather than moving progressively like a shim stack, so so long as you can get enough initial force on them I guess they'll be right. Roughly double the preload to get somewhere near.
Old 15-02-10, 11:06 PM   #19
JOHN
Where did you find the info as to valve spring stiffness? Did i miss it somewhere obvious?
It appears the valve there is designed to pop off* rather than be progressive to me, so the only difference I could see you'd need is a bit more preload on the valve.
*If it wasn't, they would use a shim stack like the matris valves.
Old 16-02-10, 10:43 AM   #20
Icanopit
Morning YC, because the very good value alternatives if suitable are a HARLEY FITMENT, I am assuming they are a near direct copy of the RT item and specification!
Using the RT listing of specifications that I have, the Harley FX series is rated at Emulator spring 40 lb/in with 3 turns of spring preload, the XL series 26 lb/in with 4 turns of spring preload.
The SV requieres an Emulator spring rate of 64 lb/in with a spring preload of 2 turns, the spring preloads are of course all start points.
I reiterate though that figures are based on the RaceTech specification tables.
The RT list does indicate that it is ONLY Harley that uses a spring rate lower than 64 lb/in, it appear's that all other makes are guided at 64 lb/in ??
Hope I have not muddied the waters, JOHN
JOHN
Race tech gold fork emulators FOO SV Talk, Tuning & Tweaking 2 31-10-08 06:44 PM
SV-650K7 & Race Tech Cartridge Emulators YZEtc SV Talk, Tuning & Tweaking 18 09-12-07 10:50 PM
sv race emulators antony SV Talk, Tuning & Tweaking 15 23-01-07 05:51 PM
Race Tech springs - where to buy? RingDing SV Talk, Tuning & Tweaking 5 13-07-06 01:15 PM
Emulators - Race Tech or Traxxion RingDing SV Talk, Tuning & Tweaking 10 02-06-06 08:57 PM
