#11 |
Also loose front sprocket nut can let oil out, but then it tends to come out rather quickly!
#12 |
As Yorkie says the seal for the front sprocket can leak if the sprocket is loose. Though I find it only a issue when your running the bike hard, say above 6k, as I've managed to leak on the motorway journey to work and then wonder why it stopped when I was bimbling round town.
#13 | |
(I think its actually wear rather than the nut loosens but the effect is the same). Check your nuts every service! Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#14 |
This is the one you need to check -
#15 |
Interesting. What with this, iffy brakes, new fork springs/oil, it looks like a busy weekend!
Thanks everyone. |
#16 |
#17 |
145 Nm per Haynes
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#18 |
#19 |
Otherwise known as FT
#20 |
See, told you it works its way loose!
Druid
Oil Leak :-( | stephencassidy | SV Talk, Tuning & Tweaking | 11 | 07-10-09 06:31 PM |
Property Developing | squirrel_hunter | Idle Banter | 19 | 08-08-09 07:58 PM |
Has anyone done any property developing? | rob13 | Idle Banter | 6 | 03-09-07 02:13 PM |
Gas leak! | imaleon | Bikes - Talk & Issues | 10 | 06-05-06 03:23 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
