Old 07-02-10, 06:42 PM   #11
Elltg
Default Re: Bike not run for a while, stalling.
Had practically no time for the bike this week. I got some carb cleaner and it said to spray it into the open carb air intakes and run the engine for a bit, that definitely helped the backfiring is less frequent and it will actually idle without the choke once warm, (idle still seems like it needs adjusting but has rusted solid) but have not yet had time to take the carbs of to properly clean.
I think its one or more of the following:
carbs need proper clean
fuel needs replacing (been sat there for best part of a year)
carbs need proper setup (rejet or balancing) since having restrictors put on and new can on.
replacement spark plugs. (same ones on it since i bought it and i am pretty sure they have been there for a good few years.
Take a look at this video and listen to the new sound of the backfiring. also if anyone can see or hear and has experience with them is the slow throttle response because of the restrictors or a lack of good airflow
VIDEO: http://www.youtube.com/watch?v=csLWpviIOos
Old 09-02-10, 03:35 PM   #12
Elltg
Any ideas guys? Im limited for time to spend on it so your feedback is invaluable. I'm going to change out the fuel today if i get a chance.
Old 09-02-10, 08:20 PM   #13
carternd
Change the fuel and clean the carbs properly, change the plugs while you're at it although if both cylinders are firing they aren't U/S, It often sweetens things up. Also look at the ends of the plugs for clues as to how the engine's running (normal, the firing end should be light brown, grey or tan coloured with a few combustion deposits - Haynes). Anything else indicates a problem. There should be a proprietary solvent/cleaner for carburettors, only thing that springs to my mind is Holts Fuel system cleaner. Someone will, no doubt, enlighten us !
Old 10-02-10, 02:10 AM   #14
Elltg
I changed the fuel today. Much nicer running now the backfiring seems to have changed to a just bassy fire rather than a pop. e.g. bob bob bob bob bob BOB bob bob bob bob BOB (if you read that out loud it is a quite good description!)
Only problem now is a low idle. and a idle adjuster so rusted it is seized! (is it replaceable? i may as well whilst i am it)
Going to take the carbs out and spray some more cleaner through them and put the non restricting sliders in and see if the idle changes because then i know it is more likely a setup issue rather than a problem with something issue.
Thinking it could simply just need a good rag but with no MOT and no front lights or gauges at current it doesn't seem plauseable.
cheers again guys
Old 10-02-10, 08:02 PM   #15
Elltg
WOOOO
http://www.youtube.com/watch?v=Ldi3zqfeA8Q
Old 10-02-10, 08:12 PM   #16
carternd
Originally Posted by Elltg View Post
Sounds like the start of Apocalypse Now!
Sounds like a working engine to me. Now get it fixed and MOT'd so you can ride the thing!
Old 10-02-10, 08:14 PM   #17
Elltg
Definitely mate. Be ready for when it warms up at the LATEST!
Gonna have more drive to get it done now! What do ya think of the reet chavvy grips and bar ends haha
Old 10-02-10, 10:27 PM   #18
carternd
Lush innit?
As long as you can hold on and they take the force of a small drop (like my disc-lock induced crash LOL) who cares. You should be looking at the road, innit bwoy!
Old 10-02-10, 10:31 PM   #19
Elltg
Been there done that and i was so embarassed, i managed to go down with it and grab the bike in a panic. Just so happened i grabbed the left bar and pulled the clutch in. and just pulled the bike straight back up! was impressed because i didnt actually stall it when i fell off in gear
Old 10-02-10, 10:34 PM   #20
carternd
Oh, I just stepped off. Right in front of a load of builders. Still
need to put the end back on my clutch lever!
Bike stalling in the rain cF^ SV Talk, Tuning & Tweaking 12 08-07-09 10:11 PM
bike stalling... toyotafj40s SV Talk, Tuning & Tweaking 3 24-08-06 06:05 PM
Bike stalling in the Rain Fife SV Talk, Tuning & Tweaking 4 14-07-06 07:50 PM
Stalling Bike doe SV Talk, Tuning & Tweaking 4 06-05-06 07:27 AM
Bike stalling TC3 SV Talk, Tuning & Tweaking 11 19-08-05 06:21 AM
