Old 11-02-10, 12:15 AM   #11
fastdruid
fastdruid's Avatar
Default Re: fubberd engine
Er, remember that bloke with the R1 I mentioned?
1) The magnets aren't metal.
2) Any bits should have been picked up by the strainer or filter, you'd be very unlucky to get any top end.
Personally I'd buy a second hand generator rotor/starter, take the sump off, clean the bits out, flush the oil and run it until it (maybe) pops. *Then* you have a spare engine!
Druid
Old 11-02-10, 04:34 AM   #12
2hys
something made the engine seize couldnt get 1st or neutal so new engine going in and i may play/fix with this one when ive got thme, wot a mess through.. that r1, mine dont look that bad
Old 11-02-10, 09:58 AM   #13
Default Re: Broken alternator magnet.
Druid you can't get the sump off an SV without splitting the cases.
Looks like exact same failure my GPZ500S had other week.
Teeth breaking off starter gear can happen if it kicks back through trying to start with a low battery.
Old 11-02-10, 10:57 AM   #14
fastdruid
fastdruid's Avatar
<small voice>I know, wasn't really thinking and forgot the SV doesn't have a classic 'sump'.
Druid
Old 11-02-10, 11:00 AM   #15
Holdup
Originally Posted by 2hys View Post
it seemes i have just won an engine with a £335 bid on fleabay (2003) with 4300 miles on it, if this is all true then im about to swap that for my (2003) 43000 mile lump of broken metal this wknd(whoo (and in deed) hoo) it does look clean through, anyone wanna give us a hand?lol
I saw that engine the other day and was about to link you too it.
Hope you get it all sorted soon
Old 13-02-10, 11:51 PM   #16
2hys
new engine all in now and bike all back together just need 2 touque the nuts add oil/water and put the battery back in then i can atempt to start it http://www.facebook.com/#!/photo.php...&id=1391552863 and i pic of the aternator http://www.facebook.com/#!/photo.php...=1351775799734
Old 14-02-10, 07:44 PM   #17
2hys
update: all working now and sounding good apart from a slight exhaust blow from where i forgot to refit the gasket from the rear down pipe to the system, D'OH. the only other thing is now the throttle is stiff/tight and wont return! any ideas
Old 14-02-10, 07:57 PM   #18
Holdup
Check you havent caught the cables up any where or from what i did the other night, check the right hand side of the throttle bodies that you havent put the pair system pipe on top of the rods that control the butterflies, i had and could only twist my throttle a tiny ammount
Old 14-02-10, 07:57 PM   #19
You routed the cables differently, move them around until they work
Old 14-02-10, 08:14 PM   #20
2hys
was hoping you wouldnt say that! i did tape them up the way they came off, ther such a pig to remove and refit, i had to remove the bodies b4 i could remove the cables
GSXR front..anyone used the magnet kit from SVrider? BoltonSte SV Talk, Tuning & Tweaking 5 09-02-10 12:37 PM
speedo drive sensor 4 magnet type coolbreeze Stuff Wanted 0 25-01-10 09:46 PM
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Rare Earth Magnet Oil Sump Plug phizog SV Talk, Tuning & Tweaking 4 06-02-08 11:11 AM
GSXR speedo conversion magnet svrash Stuff Wanted 8 25-04-06 03:15 PM
