Old 24-02-10, 10:10 PM   #11
Paul the 6th
Paul the 6th's Avatar
Default Re: a shocking state of affairs.......
shock horror
Old 24-02-10, 10:11 PM   #12
keep up the good work wide a55
Old 24-02-10, 10:16 PM   #13
Holdup
At this rate...
Funneh
Old 24-02-10, 10:25 PM   #14
Sally
How did this fit?
Any cutting of the battery box?
New bolts etc?
I am thinking of this shock for my pointy! I know there may be some differences!
Old 24-02-10, 10:31 PM   #15
Wideboy
Evel Knievel
Wideboy's Avatar
the shock was same length as the standard, everything was same really, the bottom isn't threaded on the kwak one but the standard one is, so you need a longer bolt and to put a nut on the end but cant be to long otherwise you cant re-fit the dog bones. battery box had to be cut out to fit round the reservoir and a smaller battery is also needed
05 DRZ400E
RIP hovis
Old 24-02-10, 11:01 PM   #16
Sally
Basically just a slimmer battery then!
Cheers WB
Old 25-02-10, 09:40 AM   #17
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: 2008 ZX10 Shock fitted.
Yeah, that or move it? i duno, will start looking at the weekend
05 DRZ400E
RIP hovis
Old 25-02-10, 09:48 AM   #18
-Ralph-
I've read those in the know saying you shouldn't use any old bolt, it needs to be the proper bolt, designed for the bottom of the ZX10R shock. They are stronger or summat and a normal bolt will shear. Which might not be too nice if your hitting a bump mid-corner when it goes
Old 25-02-10, 10:04 AM   #19
Wideboy
Evel Knievel
Wideboy's Avatar
Oh yeah and that, a usual bolt would shear
05 DRZ400E
RIP hovis
Old 25-02-10, 10:27 AM   #20
Wideboy
Evel Knievel
Wideboy's Avatar
High tensile bolts is the techy term, i just got them off my brother
05 DRZ400E
RIP hovis
ZX10 shock fitting problem. sprocket SV Talk, Tuning & Tweaking 26 10-03-10 09:09 AM
ZX10 Shock on a Curvy TheShadow SV Talk, Tuning & Tweaking 27 15-06-09 10:33 PM
ZX10 rear shock advice [yet again] tonny006 SV Talk, Tuning & Tweaking 7 22-09-08 04:49 PM
zx10 shock skapegoat SV Talk, Tuning & Tweaking 10 20-01-08 10:02 AM
ZX10-R '04 Rear Shock - Curvy Upgrade pmapp For Sale - SV's and SV related items 5 01-10-07 09:02 AM
