Old 22-03-10, 08:53 PM   #11
Stuuk1
Default Re: Cbr 600F 2001
another question... is that expensive to fix?
Old 22-03-10, 08:56 PM   #12
AndyBrad
60 quid all in
Old 22-03-10, 08:57 PM   #13
Stuuk1
lovely jubly!
Old 30-03-10, 04:30 PM   #14
muffles
I believe the fuel injected F's have cartridge forks (and possibly some before then, FX/FY and *maybe* even before - I can't be sure from a quick google). I have my forks apart at the moment if anyone (YC ) can identify that from the component parts? The lowers are away being powdercoated
Old 30-03-10, 04:34 PM   #15
cartridge looks a bit like a syringe... about 23-26mm in diameter with rod sticking out of top that is threaded into top cap.
A damper rod is fatter, doesn't screw into the top cap. Post a pic if that doesn't make sense.
Old 30-03-10, 04:35 PM   #16
muffles
Actually I might not have the bit apart that tells you - this picture http://forks.darladog.com/cart_bottom.JPG shows you the piece I have, I haven't undone the bottom of that (didn't need to) but it looks pretty much the same (but then do all forks have this inside? It seems like the difference is internal to that piece?).
Old 30-03-10, 04:37 PM   #17
Nope that assemble is the cartridge.
inside that you have valves, a damper rod fork is completely different (and crap)
Old 30-03-10, 04:37 PM   #18
muffles
I can post a pic of mine tonight I've got the top caps separate from the damper piece shown in the previous post, but I can't recall if they screwed into the top caps or not (the top of the damper piece has the suspension adjuster bits & goes through a hole in the top cap). The damper piece is quite a small diameter - around the figure you mention, though.
Old 30-03-10, 04:37 PM   #19
muffles
You post too quick cool, so it has cartridge forks - good to know !
Old 31-03-10, 05:30 AM   #20
lukemillar
Originally Posted by muffles View Post
I can post a pic of mine tonight ..The damper piece is quite a small diameter...
2001 R6 any colour parkinmj Stuff Wanted 1 21-04-09 07:48 PM
CBR 600F & 600FS Differenences Hockeynut Bikes - Talk & Issues 7 21-03-08 06:27 PM
cbr 600f exhaust - does anyone want it? mary Idle Banter 4 01-02-08 10:37 AM
2001 naked kitaco kid For Sale - SV's and SV related items 42 01-10-07 08:07 PM
SV650S 2001 X Reg Loubie For Sale - SV's and SV related items 0 02-10-06 02:24 PM
