Old 22-04-10, 02:44 PM   #11
beabert
Default Re: Valve clearances = New Gasket?
I just applied a little gasket dressing stuff from halfords
Old 22-04-10, 10:24 PM   #12
SAMMY650
Originally Posted by Spanner Man View Post
Not grease young fella. A little silicone sealant around the cut outs. (These are the half moon shaped things).
Make sure you clean all the old sealant from the cylinder head, & the gasket itself before replacing the cover, or it'll probably leak.
If the gasket comes away from the cylinder head cover, hold it in place with a few drops of Superglue on the outside edge only.
Cheers.
Is this the stuff I need?
http://www.halfords.com/webapp/wcs/s...egoryId_165691
Old 23-04-10, 06:07 AM   #13
Spanner Man
Originally Posted by SAMMY650 View Post
Good morning all.
That will do nicely. Just make sure all of the old sealant is removed before applying the new stuff. Brake cleaner seems quite effective at lifting old gasket compound.
Spanner Man
Valve Clearances stratman_001 SV Talk, Tuning & Tweaking 2 09-03-10 01:13 PM
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
