Old 07-05-10, 04:07 PM   #11
wyrdness
Default Re: Why is my internet slow?
I thought ADSL routers worked best on the BT master socket.
Yes and no. See my post above. If you disconnect the bell wire at the master socket and run good quality cable (not the cheap stuff from DIY superstores) to the extension, then you shouldn't get a drop in speed at the extension socket.
Old 07-05-10, 04:23 PM   #12
Slight derail. Perhaps this is why my Sky+ box's modem won't talk to sky through a cheapo diy cable
Old 07-05-10, 04:29 PM   #13
-Ralph-
Thanks for all the replies guys. It has actually been absolutely fine since I hard wired the laptop to the router (which is fine because I use a docking station). Maybe moving the router has caused it to fight with a neighbours.
I'll put it back onto Wifi and set up a ping tool to log a continuous ping to the router, to my public IP gateway, and to a couple of websites. If they all drop out at once it's my wifi, if the public addresses all drop out at once it's my ADSL connection, and if only the website addresses drop, it's Orange. If Orange I'll do some tracert's and give them a phone.
Old 07-05-10, 04:31 PM   #14
wyrdness
That's more likely to be a bad connection or broken wire, or else the modem in your sky box is kaput. Sky boxes use standard dial-up, so won't be as sensitive to cheap cable as adsl modems.
Have you tried plugging a normal phone into the extension socket and seeing if that works?
Old 07-05-10, 04:33 PM   #15
Yes, but even through a hand set there's noise on the line. Might be because of an old line from the front of the house to the new telephone socket?
Sky box can talk to sky when everything is disconected from the main socket
Old 07-05-10, 04:40 PM   #16
wyrdness
That sounds a bit beyond my knowledge of phone lines. Do you have adsl and, if so, are you using microfilters to isolate normal phones from the adsl signal?
Old 07-05-10, 04:44 PM   #17
Yes, and I've tried every combination of extention socket & micro filter you can think of. When I've got the wrong combination, the line noise on my telephone line is horrendous.;
All it means is my sky box can't order sky movies, so its skys loss, not mine.
The answer is to have a proper line installed incl the extentions
Old 07-05-10, 04:50 PM   #18
qwerf
Yeah, always best to have it in the master socket now adays, especially as the new BT sockets come with the new I-Plate which is suppose to increase speed as it filters out alot more, Also have the bare minimum extensions, if you've got an old one unused, whip the master socket off and disconnect the old socket! Less likely to generate a fault on your line
Old 07-05-10, 04:53 PM   #19
-Ralph-
So nobody else got slow broadband because of the election today then?
Old 07-05-10, 04:58 PM   #20
No, mines been fine all day. Perhaps it was just your exchange?
IT Geeks - Slow internet andyb Idle Banter 0 17-04-10 06:03 PM
Got new internet security, and now internet is sooo slow neio79 Idle Banter 9 19-07-07 10:54 AM
slow internet tonight? kwak zzr Idle Banter 5 14-11-06 09:41 PM
Slow Internet Reckless Rat Idle Banter 7 23-08-06 10:19 PM
