Old 27-05-10, 02:06 PM   #11
breakz187
Default Re: Slipping out of 2nd gear.
My 08 sport slips out of gear quite often, always after a clutchless change up and usually as I'm accelerating hard and all of a sudden, revs are screaming and there's a lack of forward motion! Can happen a good 5-10 seconds AFTER the change up too
Mine does exactly the same, until i do the chain and lube that lever joint.
Old 27-05-10, 03:42 PM   #12
tommyboy
well i recently cleaned my chain and lubed it all up, so its not that i hope.
this is pretty damn embarissing and could theoretically be the problem. i mostly ride my bike to college, and jus wear trainers as I dont fancy walking like some cowboy. therefore it's most likely my limp ankled gear changes. maybe i ought to wear my boots more often what a d**khead.
apologies.
Old 27-05-10, 05:31 PM   #13
Nobbylad
Nobbylad's Avatar
I have a scottoiler that I fill up about once every fortnight.
Might check the lever linkage
Old 27-05-10, 06:36 PM   #14
check the chain and clutch
and the gear lever posistion as it may be to low for u
Slipping and Sliding ClemsonSV Bikes - Talk & Issues 10 22-06-07 12:04 PM
Slipping out of Gear....nudists huh! Inc wheelie pic Vtwinlover SV Talk, Tuning & Tweaking 33 21-08-06 09:00 PM
Clutch Slipping. Iceman SV Talk, Tuning & Tweaking 15 04-01-06 07:04 PM
Slipping and sliding beefcake Bikes - Talk & Issues 5 07-09-05 11:27 AM
Clutch slipping? Supadan SV Talk, Tuning & Tweaking 18 12-06-05 05:43 PM
