Old 20-07-10, 02:39 PM   #11
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: upgrade horn
Quiff, I got a pair of Magnums that I was going to fit to the ADV, but then realised there was nowhere to fit them that wouldn't fill with water on a deep crossing
If you want I can bring one to the AR? If you're really lucky I might have a ready made relay harness as well, but I'll have to check the garage
Cost you a cider at the bar
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 20-07-10, 02:43 PM   #12
Mark.. that sounds like a deal mate..
Old 20-07-10, 02:45 PM   #13
wyrdness
Originally Posted by Viney View Post
I think that the magnum or a single motrax don't need a relay, However, if you use somthing like twin FIAMMs, then you do. its fairly simple even for a northerner like yourself.
I've never bothered fitting a relay with Magnums. I checked the datasheet once and the current draw wasn't sufficient to warrant a relay. However, some people fit one just to be on the safe side.
Old 20-07-10, 03:55 PM   #14
Luckypants
Luckypants's Avatar
Quiff mate, I'd fit a relay since they are buttons and a doddle to fit. It's not worth the risk of damaging the loom for a few quid.
The problem with the Viffer is where to mount the damn things. There is very little room under the fairings to mount the trumpets / horn and even less if you go for air horns and need to mount a compressor. It's something I've wanted to do on mine for ages, but cba looking for somewhere to mount stuff.
As I understand it, you are in luck as there is room under the top left fairing for a horn / compressor on bikes with no ABS, as there is a void there for fitting ABS gubbins. For me there is nowhere to fit them easily (but I have an idea I just thought of!), so would be interested to see how you do.
Old 20-07-10, 04:03 PM   #15
the_lone_wolf
Captain Awesome
You in luck Quiff-dude
Just rooted around the garage, got a ready made loom to hitch you up, all you need is a relay
Cya in a few weeks!!!
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 20-07-10, 04:08 PM   #16
Its easy to split the compressor from the Stebel Nautilus so its in 2 bits.
I stuck the compressor under the Sv passenger seat and the now lightweight plastic horn in the Sv's left fairing. Connected compressor to horn with a length of plastic pipe
Used the horn wiring to power the relay.
If you get a Nautilus then make sure you buy the Mini version, as the horn section is smaller, but the compressor is the same size.
The Magnums I fitted were'nt as loud as my single Nautilus
Old 20-07-10, 04:11 PM   #17
Luckypants
Luckypants's Avatar
Fitting an upgrade horn to an SV is no problem, unfortunately the Quiffster has a VFR. There is very little room for anything on them, especially under the seat!
Old 20-07-10, 09:33 PM   #18
will let you know.. but if I waiting til Mark provides me with a freebie it will be at the AR .
New Horn? XmisterIS Bikes - Talk & Issues 22 13-11-09 02:04 PM
No Horn pin64 SV Talk, Tuning & Tweaking 1 19-07-09 12:11 PM
Ive Got the Horn Blue Flame SV Talk, Tuning & Tweaking 33 27-05-08 04:01 PM
Are you getting the Horn? DanDare Bikes - Talk & Issues 3 06-07-06 12:56 PM
Horn Upgrade moodyman SV Talk, Tuning & Tweaking 5 22-05-05 05:22 PM
