Old 02-11-10, 12:15 PM   #11
husky03
Default Re: Attempted theft - ignition barrel damaged
Originally Posted by nille View Post
But its just one key and doesn't lock original too.
a new key is 4 quid mate and unless your an idiot you'd change all the locks hence it being a COMPLETE lockset ffs
Old 02-11-10, 12:24 PM   #12
thats not expensive for a complete lockset mate
Sorry, yep, what I meant was Berlin's might not be as much as the Ebay one.
Berlins has 2 keys as well
Old 02-11-10, 12:27 PM   #13
husky03
60 bangers delivered from carl was what he quoted bigchris
Old 02-11-10, 12:30 PM   #14
Blimey The other ones a bargain then
Old 02-11-10, 12:38 PM   #15
husky03
hehehe- hence why i pointed that seller out to him mate.the ignition barrel only is on the bay for 25 quid plus 9 delivery so its worth the 40 quid for everything(but i'd best offer 35)
h.
Old 02-11-10, 01:30 PM   #16
nille
Typo. I was refering to the key which doesn't loOk genuine.
Sure would change all locks when buying a COMPLETE lock set.
Before I buy a new set I would bolt out the lock-cylinder and try to repair it.
Lock inner parts can't be more than bent and if the cylinder is damaged I can offer the pictured one for free.
Old 02-11-10, 01:53 PM   #17
SVMAT
As above id suggest trying to repair it first. The same thing happened to my sv. You need to undo 2 security torx on bottom side of yoke then barrel will come free, then undo 2 philips screws on top and remove cap and you can pull out the actual barrel insert thingy. It is actually more simple than it sounds or looks. I ended up rubbing down the brass inserts substantially hence now you could prob start my bike with a spoon. Sorry if youve already tried this just trying to help.
Matt
Old 02-11-10, 02:53 PM   #18
apple tango
Matt
Thanks.
Do you, or anyone else know if I will need a drill with a torx bit attached to undo the security screws? Or would a screwdriver with a torx bit be sufficient?
Old 02-11-10, 07:37 PM   #19
monkey
You definately won't need a drill unless you want to drill something
Old 02-11-10, 09:03 PM   #20
Originally Posted by apple tango View Post
Thanks.
Drill won't do it and screwdriver with torx might do it if you're lucky.
But I needed a rachet & the torx bit in an adaptor on the ratchet to get enough leverage to start undoing it.
Suzuki use some really strong oranage threadlock when they assemble the yoke.
Attempted theft of my SV danf1234 Bikes - Talk & Issues 10 13-05-07 01:24 PM
Attempted theft damage ... help needed!! The Bride SV Talk, Tuning & Tweaking 3 27-02-07 10:02 PM
Attempted Theft Foiled Baph Bikes - Talk & Issues 25 14-09-06 01:38 PM
attempted theft Anonymous Bikes - Talk & Issues 30 01-07-06 05:36 PM
Attempted theft - Beckenham cyphertheory SELKENT 4 01-06-06 11:43 AM
