Old 09-11-10, 05:46 PM   #11
beabert
Default Re: Clutch or Gearbox? Or Both?
If you do replace the clutch plates dont get ebc ones they break easily, broke 3 of mine in 500 miles.
Old 09-11-10, 06:03 PM   #12
petevtwin650
Default Re: Clutch or Gearbox? Or Both!?
Things to be wary of removing clutch plates are overtightening of clutch cover
Is there not an issue with being careful with the platic clutch cover, Chris, or have I been out of the loop too long?
Doh! Somehow I thought you meant the pressure plate bolts.
Old 09-11-10, 06:04 PM   #13
Probably worded badly, but both actually! If not careful you can strip the pressure plate bolts too, though you've got to be pretty hamfisted.
Old 09-11-10, 07:28 PM   #14
Rob969
Did the clutch start dragging after changing the oil? after i changed the oil in mine i had an issue with it creeping forward when the revs rised but only when the bike was cold, spoke to my local garage and he said that it sometimes happens after changing the oil but wasn't sure why and told me to keep an eye on the oil level and see what it was like after a few rides about a week later all was fine and its been fine for the last 6 months can't help with the slipping clutch problem though sorry
Old 11-11-10, 11:21 AM   #15
naj1987
Cheers everyone for the advice, now all I need is a dry day and I'll check out all the things you mention. Thanks again.
K3 gearbox muzikill Stuff Wanted 0 12-08-10 08:34 PM
Life expectancy of clutch/gearbox? bhd SV Talk, Tuning & Tweaking 9 08-08-10 02:39 AM
Clutch/gearbox issue? metalhead19 SV Talk, Tuning & Tweaking 3 02-03-10 04:04 PM
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
