Old 12-11-10, 08:34 PM   #11
CSpronken
CSpronken's Avatar
Default Re: Another front end conversion
Originally Posted by fastdruid View Post
k0-3 forks and wheel bearings are 7mm narrower than SRAD, would probably be easier with an SRAD wheel and spindle
Dang, I was afraid of that, but could not find the info. It's an option, but what fender will fit then, SRAD or K0-3?
Otherwise you'll need two 3.5mm spacers for the wheel and for the disks/calipers.
Hmm, as long as I know it works in the end I'm willing to try.
Where are you? If you're midlands I've got a 'Spare' SRAD wheel you could try for fit.
Druid
Very kind of you, but live across that little stretch of water where you lot and us cheese heads had our occasional exchange of round metallic objects.
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going.
CSpronken is offline   Reply With Quote
Old 12-11-10, 10:08 PM   #12
fastdruid
fastdruid's Avatar
Probably SRAD, although K0-3 may fit if you're prepared to stretch it a bit.
Druid
Old 14-11-10, 02:33 PM   #13
CSpronken
CSpronken's Avatar
Druid
According to Northwind they do, so my updated plan would be:
- Buy the TWF bearing
- SRAD top and bottom yokes
- GSXR K0-3 forks (Hayabusa or K4-5 springs if needed)
- SRAD/TL/Hayabusa wheel and axle
- Any Suzuki 320mm disc (TL has 134mm rotors centres, K0-3 132mm?)
- GSXR K0-3 calipers
- M8 washers on the calipers
- GSXR K0-3 fender
- TL1000S clip-ons
- 120/70 front tire to compensate for the shorter forks
- Speedo to the rear (final decision still pending)
- take a mm or so off the ignition bolt
- steel braided brake hoses
- Possibly paint the fender
- Check if the standard GSXR springs (0.78 ) are stiff enough (racetech advise for my and bikes weight 0.85).
Are there any differences in the way the mudguards are bolted onto the forks through the different years. In other words, ignoring yoke width for a moment, are they interchangeable, for instance bolting a K0-3 mudguard onto SRAD forks?
Old 14-11-10, 03:24 PM   #14
Default Re: Another front end conversion. Parts list.
They changed mountings around a couple of times, some have 3 mountings... SRAD shape has 2 mounts and is same shape for years... way back into oil boiler years (80s) that are same fitment just slightly different shapes. Eg GSXR400GK76 one will fit SRADs, TLs etc.
Best bet is to look on eBay... see the different mountings stuck out of fork legs and compare.
Old 14-11-10, 04:13 PM   #15
Berlin
I've got a spindle thats been modified to allow SRAD wheels to be used in std K1-K3 forks. I can measure the difference if you like, its not much. I've also got a front wheel and some other bits from the 600 too.
C
Old 14-11-10, 07:29 PM   #16
CSpronken
CSpronken's Avatar
C
How exactly is it modified, why is it needed? Well I would need a SRAD wheel and disc, preferably no paint.
Old 14-11-10, 07:46 PM   #17
Berlin
Its machined so it lines up an SRAD wheel in K1-K3 forks and yokes. Working backwards from that should tell you where you need to be.
C
Old 15-11-10, 01:48 PM   #18
CSpronken
CSpronken's Avatar
C
Was it a SRAD axle you used for the modification? Sorry to be a bit thick.
I need a list of parts? martin.sv750 SV Talk, Tuning & Tweaking 4 29-09-08 06:54 AM
Gsxr Front End Conversion Parts gruff For Sale - SV's and SV related items 13 06-06-08 06:40 PM
GSXR front end parts for pointy conversion. svdemon Stuff Wanted 37 21-04-08 08:08 PM
For sale: GSXR front fork conversion parts!!! Knaapie For Sale - SV's and SV related items 9 24-05-06 07:45 PM
GSXR SRAD 750 USD front end conversion parts silent For Sale - SV's and SV related items 12 26-04-06 11:00 AM
