Old 12-11-10, 05:35 PM   #1
CSpronken
CSpronken's Avatar
Default Another front end conversion. Parts list.
I know there are plenty of threads already, I just want to explain my plan and if I forgot something or if there would be any additional advise. I have a 2002 Curvy and this would be a little project for the winter.
The plan:
- Buy the TWF bearing
- SRAD top and bottom yokes
- GSXR K0-3 forks - GSXR K0-3 axle
- GSXR K0-3 wheel
- GSXR K0-3 discs and calipers
- GSXR K0-3 fender
- TL1000S clip-ons
- 120/70 front tire to compensate for the shorter forks
- Speedo to the rear
- take a mm or so off the ignition bolt
- Powder coat the rear wheel black as the GSXR front, possibly paint the fender
- Check if the standard GSXR springs (0.78 ) are stiff enough (racetech advise for my and bikes weight 0.85).
- Sell my SV front end (2002 preload adjustable with progressive springs if anyone wants it)
Is there anything I've forgotten?
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going.
CSpronken is offline   Reply With Quote
Old 12-11-10, 05:37 PM   #2
Default Re: Another front end conversion
You might need to space calipers in a bit
You already have that dust seal on your bike, no need to buy another.
I think you over simplify the "put speedo to rear" step
Old 12-11-10, 05:41 PM   #3
CSpronken
CSpronken's Avatar
Why is that exactly, cause of matching the SRAD yokes with the GSXR forks? basically the whole front end will be GSXR K0-3 except for the yokes.
Excellent, removed it from the list.
Well I'm still hoping I can get that guide somehow.
Cheers.
Old 12-11-10, 05:45 PM   #4
Think about what calipers care about WRT discs... first being in right position radially... that is no problem 'cos you are matching disc and fork (320mm dia disc aye, SRAD ones are the same too FYI). But axially... the caliper must sit around the disc... if it is too far in or out it will foul (especially with new pads).
So distance between forks is controlled by yokes but affects caliper to disc fit. Maybe you would even be better using SRAD wheel as it may (fairly sure it has) have a wider hub to make up for the greater width of yoke. You may even use SRAD spindle too.
TBH without measuring everything it is hard to say... wait for someone who has done it... or just bolt it all up (before you strip SV down!!) and see whether it fits. that is best way
Old 12-11-10, 05:46 PM   #5
fastdruid
fastdruid's Avatar
I found it was easier just to not clean the rear wheel[1].
Druid
[1] But then I had the 'charcoal grey' wheels rather than silver and there wasn't a lot of difference between them and the black 'busa/SRAD wheel.
Old 12-11-10, 05:48 PM   #6
fastdruid
fastdruid's Avatar
IIRC SRAD are wider than K0-3, certainly the SRAD wheel won't fit K6-8 (actually it might *just* but it'd be very tight).
Best is to stick with an entire front end.
Er have you got any TLS bars yet? I seem to have 4 (two sets) which I'm planning on selling.
Druid
Old 12-11-10, 05:50 PM   #7
SRAD keeps steering lock and such though, and has been done to work well with K1-3 forks which are a bit nicer.
Old 12-11-10, 06:21 PM   #8
CSpronken
CSpronken's Avatar
That's the thing, I have a chart ("sam's fork chart" link) with info about all last decades Suzuki's sportbikes forks and stuff, the only thing missing for me is the SRAD. So I don't know if it also has the 207mm yoke centre distance. I do think that Northwind basically has this set up.
I chose the K0-3, because it is available, has a stiffer spring than SRAD (0.78 vs 0.75) and the fender looks less agricultural.
Druid
LOL, I know where you're coming from there.
Druid
No I don't have the TLS bars yet and yes would be interested (pm me for price). Just need to see how the deal with the GSXR front end works out if I can collect all the needed info to do this myself.
Yup that's the idea.
Old 12-11-10, 06:55 PM   #9
here is a good chart.
http://www.twfracing.com/vbforums/showthread.php?t=529
i'd be inclined to get forks brakes and yokes put them on and measure. but as chris said srad wheel will most likely fit.
Bibio is online now   Reply With Quote
Old 12-11-10, 07:12 PM   #10
fastdruid
fastdruid's Avatar
As per
and
k0-3 forks and wheel bearings are 7mm narrower than SRAD, would probably be easier with an SRAD wheel and spindle.
Otherwise you'll need two 3.5mm spacers for the wheel and for the disks/calipers.
Where are you? If you're midlands I've got a 'Spare' SRAD wheel you could try for fit.
Druid
I need a list of parts? martin.sv750 SV Talk, Tuning & Tweaking 4 29-09-08 06:54 AM
Gsxr Front End Conversion Parts gruff For Sale - SV's and SV related items 13 06-06-08 06:40 PM
GSXR front end parts for pointy conversion. svdemon Stuff Wanted 37 21-04-08 08:08 PM
For sale: GSXR front fork conversion parts!!! Knaapie For Sale - SV's and SV related items 9 24-05-06 07:45 PM
GSXR SRAD 750 USD front end conversion parts silent For Sale - SV's and SV related items 12 26-04-06 11:00 AM
