Old 19-12-10, 06:56 AM   #11
MattCollins
Default Re: Alternative stand for rear wheel lift.
Yep, £48 is waaay too much. Similar products are worth about $25 (£15).
I carry a prop and a couple of straps on anything that doesn't have a centre stand. It is there for the sole purpose of keeping the bike off the ground during a tyre repair. If you call the AA for a flat then don't bother.
Never, ever use one of these things in the workshop... get a paddock stand.
PS. Forget the Scottoiler... The Pro-Oiler is a better product.
Old 19-12-10, 08:26 AM   #12
Berlin
The perfect present for someone that, no matter how hard they looked, couldn't find a stick, tree, branch, brick, bush, hammer, screwdriver, spanner, chock, pipe, axel stand or any other of a thousand things that would do the job in the same way, for free.
C
Old 19-12-10, 08:31 AM   #13
toxic
I don't like the look of that. When oiling chain without a stand I just lift the rear wheel using the side stand and front wheel as balance, then rotate the rear wheel with my right toe. It's a lightweight bike anyway, not a gold wing.
Old 19-12-10, 10:19 AM   #14
C
Haha
You forgot Broom shank and bench!!!
Old 19-12-10, 11:33 AM   #15
AndyBrad
ive tried that so many times and failed at every attempt! i know im a light weight but come on there must be a knack to it.
Old 19-12-10, 01:01 PM   #16
toxic
Bike on sidestand, steering against left lock stop, left hand pushing down on left grip, right hand on rear grab handle, lift with right hand. Spin rear wheel with right toe... That is the knack.
Old 19-12-10, 04:26 PM   #17
21QUEST
21QUEST's Avatar
A piece of wood from the skip would do the same job. If feeling talented, you could cut a slot to the shape of your swinging arm....most probably recommended for the more clumsy folks anyway :P
For years I used part of a branch from a felled tree, which was conveniently forked at one end..
Not a bad idea to put a chuck of sorts on front tyre or wedge it against a wall etc.
Nemo me impune lacessit.
Old 19-03-11, 05:36 PM   #18
toxic
And it's environmentally friendly!
Bargain Hydraulic lift/stand? benji106 Bikes - Talk & Issues 6 29-09-10 01:39 PM
Removing rear wheel with no stand? lily Bikes - Talk & Issues 36 24-04-10 10:57 AM
Bike Rear Wheel Lift Stoneyginger SV Talk, Tuning & Tweaking 11 15-04-08 02:07 PM
Head lift stand - advice needed please. ejohnh SV Talk, Tuning & Tweaking 4 07-07-07 07:13 PM
NWS Bike Lift Stand swamp For Sale - SV's and SV related items 5 06-12-06 11:24 AM
