Old 23-04-10, 05:14 PM   #1
lily
Default Removing rear wheel with no stand?
Hi all,
drew is currently being recovered home as he has a screw in the rear tyre.
Is there any way he can remove the rear wheel with no stands ie. using just wood, car jack etc. (a safe way) as need to remove the rear wheel to get repaired tomorrow before work on monday.
many thanks
x
Old 23-04-10, 05:39 PM   #2
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Default Re: Removing rear wheel with no stand? Help
Originally Posted by lily View Post
Hi all,
many thanks
x
Two hours later and still waiting to be collected. I do have an abba stand but not the daytona fitting kit, so not sure if SV bits would work on it. gutted.
"Feckinnnn Unluckkeeeeeeee"
Old 23-04-10, 05:49 PM   #3
Sosha
Well they might fit well enough...
Not possible to plug and ride it to a tyre place?
(used superglue & just screwed the screw back in once but not sure I'd recommend it)
edit: have also used car jacks but " safe" would be debateable
Old 23-04-10, 05:53 PM   #4
barwel1992
2 car jacks ether side of the swing arm at the back just under the bolt's with the front brake zip tied on will need some one to hold the bike, works on the sv but no idea about the tona
Old 23-04-10, 06:12 PM   #5
davepreston
have a look at how me and yc did it at gm2 (photos section)
true skill and bodging
Old 23-04-10, 06:38 PM   #6
AndyBrad
ahh we need a linky dp..
is it a single sided swingarm?
Old 23-04-10, 06:41 PM   #7
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
no its dual, which is why im hoping that my sv abba fittings may just work. Otherwise, thinking might have to try car jack and axel stands on swingarm.
Now sat in services petrol station as he needed fuel. Called it in nearly three hours ago!!!!!
Old 23-04-10, 06:42 PM   #8
lily
no it's double swingarm, the bike will need to stay whatever it is on for the day, as dropping the tyre off in the morning and picking it up before they close. And I don't really want to stand outside holding it for the whole day!
Old 23-04-10, 06:47 PM   #9
Push it over on the sidestand and prop some bit of it up with a block of wood.
Old 23-04-10, 06:50 PM   #10
davepreston
http://forums.sv650.org/showthread.p...lencoe&page=11
Pointy stand for removing swing arm / shock etc Spokey SV Talk, Tuning & Tweaking 12 17-10-08 11:52 AM
Removing the rear wheel gilby104 SV Talk, Tuning & Tweaking 20 26-09-08 08:27 PM
what to do with the belt when removing the rear wheel on a buell kwak zzr Bikes - Talk & Issues 4 15-11-07 09:00 PM
What's the best stand to support the bike, while removing forks DarrenSV650S SV Talk, Tuning & Tweaking 23 30-10-07 05:51 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
