Old 06-07-08, 02:45 PM   #1
gilby104
Default Removing the rear wheel
have just gone to the bike to find i have a puncture. want to remove the rear wheel myself. have jacked it up from the rear suspension linkage which is underneath the bike. im really looking for an absolute idiots guide to taking the rear wheel off and putting it back on. do you have to take the rear brakes off? which bolts need taking off, just loosening, stuff to remember, getting the chain off etc. would really appreciate the help. its a 2003 pointy 650.
Old 06-07-08, 03:11 PM   #2
tanis34
Default Re: removing the rear wheel
http://www.sv650.org/sv_manuals.htm
Old 07-07-08, 06:21 AM   #3
Red Herring
Red Herring's Avatar
Default Re: Removing the rear wheel
Not sure I'd want to be taking the rear wheel out with the bike balanced on a jack under the linkage, especially for the first time when there is going to be a certain amount of pushing and shoving going on.
If you are going to get into this sort of activity it might be worth investing in a paddock stand, makes lubing the chain etc a great deal easier as well (circa ?30 - ?40)
If it is only a puncture can you inflate the tyre and see if it is only a slow one? If so you would then be able to ride to where ever is going to fix the puncture and they will probably have not just the paddock stand but the expertise to show you how to use it, and take the wheel out.
Old 25-09-08, 06:52 PM   #4
Dave20046
Dave20046's Avatar
Quick question - in the manual it says use a special seal remover to remove a seal in the wheel, is there an alternative?
Old 25-09-08, 07:10 PM   #5
Saint Matt
You can use a screwdriver, be careful not to scratch the inside of the wheel where the seal sits.
Old 25-09-08, 07:17 PM   #6
Dave20046
Dave20046's Avatar
Thumbs up Re: Removing the rear wheel
cheers- off to the garage now
Old 25-09-08, 07:18 PM   #7
Davido
May be worth loosening off the wheel nuts before balancing the bike. That way you minimise the chances of it making an unplanned trip across the garage.
Old 25-09-08, 07:40 PM   #8
Dave20046
Dave20046's Avatar
I'll put it back down now! cheers, just nipped back in for some allan keys
Old 25-09-08, 08:09 PM   #9
scottjames
buy your self a haynes manual. ive found it a great help to to have in case. few on ebay.
for 30 40 quid you can get front and rear padok stands they are a great help. having both will also mean you can save a few quid when changing tyres as you can take just the wheels in. most places will do it while you wait then.
scott
Old 25-09-08, 08:31 PM   #10
Dave20046
Dave20046's Avatar
Just got it out thanks for your tip davido - taking it to the shop now.
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Removing rear fender Jamie Slick SV Talk, Tuning & Tweaking 1 26-04-08 07:20 AM
what to do with the belt when removing the rear wheel on a buell kwak zzr Bikes - Talk & Issues 4 15-11-07 09:00 PM
Removing the mudguard - front wheel off? Tiger 55 SV Talk, Tuning & Tweaking 14 29-08-07 10:54 AM
Removing rear fairing elqueson SV Talk, Tuning & Tweaking 15 14-11-06 08:58 PM
