#11 |
#12 |
A method that I've used in the past is to file two sides of the stud down, so I can get a good grip with the molegrips or a spanner.
Tom |
#13 |
I'd say have a pop first.
I've had the pleasure of welding a nut on a snapped stud & found that tacking was no good (kept shearing off). When I gave it some proper weld the nut melted but instead of using the socket set I went to the stud extractor which saved the day. Later that year the other stud sheared off inside the head (yay). I bought one of these http://www.aldn.com/Pages/drillOut.php which is the bomb. Good luck. p.s. sux re hotmail |
#14 | |
![]() where did you get your's from Last edited by barwel1992; 07-01-11 at 10:24 PM. |
#15 |
ordered one of them, if that dosn't work its off to the machine shop any way
#16 |
Most of the broken stud/bolt extractors only work well if the fastener has been broken simply through being over torqued - if a substantial part of the threaded section has corroded in place they are far less useful IME. Welding a nut on has only failed me a few times, and then only when there wasn't enough stud protruding. Ultimately, drilling out the bolt and using a heli-coil if necessary is a cheap and permanent fix.
#17 | |
#18 |
Anyone any good at removing a bit of broken stud from an engine? | Seggons | East Anglian Revolution | 12 | 12-07-10 07:04 PM |
99 (curvy) Exhaust Stud Things | vardypeeps | SV Talk, Tuning & Tweaking | 9 | 31-10-08 08:59 PM |
Snapped Exhaust stud! | spacehog | SV Talk, Tuning & Tweaking | 4 | 22-05-08 08:21 PM |
Removing Exhaust a Stud | Grinch | SV Talk, Tuning & Tweaking | 50 | 28-02-08 11:08 PM |
exhaust stud | dirtydog | SV Talk, Tuning & Tweaking | 13 | 14-02-06 04:07 PM |
