Old 21-01-11, 10:56 PM   #11
Jordy
Default Re: Best springs for curvy?
Originally Posted by curvy custard View Post
im up for changing the rear too, thats why credit cards were invented and why im doing lots of overtime at present lol
Tempted to get one of those lol not sure I can trust myself though.
Old 22-01-11, 05:27 PM   #12
curvy custard
Haha
What you budget for the rear?
once ive changed the fronts and got a couple of other little bits, ill have a think about it. i wouldnt change the front suspension on a car without doing t he rears, so it makes sense to do them together on the bike
Old 22-01-11, 05:57 PM   #13
RenascenceBlue_
At your weight, I would have said the standard springs are fine!!?!?!?
There are two ways to play the SV front forks.
1. Progressive springs and thicker oil (depending on weight)
2. Linear springs and emulators.
Option 2 gives the best functioning suspension, but is ~£100 more expensive to do.
Option 1 is ample - unless you intend to race it, then you need option 2!
For more info on progressive springs, look at the following thread, which was posted by a thoroughly pleasant and helpful chap!
http://forums.sv650.org/showthread.php?t=118024
Oh and there is a 3rd option, which is GSXR front end swap!
Old 28-01-11, 06:49 PM   #14
curvy custard
i find the front end very soft thou. could this be down to needing an oil change instead?
is a gsxr front end that much better then the linear and emulator option?
Old 28-01-11, 07:39 PM   #15
Originally Posted by Jordy View Post
Is it dangerous to only upgrade the front? I just read this:-
Does this require changing the rear shock as well to maintain balance between the front/ rear?
Yes. If you stiffen up the front end w/o increasing the rear ride height you will find that the bike has way too much weight on the back of it. As you get moving quickly (100? mph or so...) the bike will start wobbling, then headshaking. Bad. Very bad. When I bought my bike it was stock, it was friday pm, and I was racing the next day. Added preload to the front forks to get the proper sag. It wobbled BAD. Dropped the front ride height, and it still wobbled. Played around in EVERY morning session (****ed off race control..) trying to get the bike to work, then I gave up and put it back to stock preload and ride height and it stopped wobbling.
And who is writing that exactly?
Old 28-01-11, 08:16 PM   #16
Jordy
http://www.sv650.org/sv_faq.htm#SV650 Suspension FAQ
Scroll down and click on 'Can I fit a GSXR frontend to my SV?' Not sure who wrote it.
Old 28-01-11, 08:25 PM   #17
davepreston
Default Re: Best fork springs for curvy?
well due to the dollar sign its a contribution from one of our americian cousins
Old 29-01-11, 10:32 AM   #18
RenascenceBlue_
not done the gsxr swap myself, but yes, it will be better as they are proper cartridge forks and will work better. the emulators are a fudge of the real thing.
all that said, unless you want to race or trackday it (racing only allows EDIT: standard forks (external) by the way) then emulator or just progressive more than enough.
Old 29-01-11, 10:37 AM   #19
Who says racing only allows emulator?
Old 29-01-11, 10:40 AM   #20
RenascenceBlue_
although him mixing pre load and stiffness (losing all credibility in the rest of what he said ) ... the essence of what he is saying is actually true - even if his experience noted there is actually something different entirely.
'stiffen the front and you will need to stiffen the rear or the bike will become unbalanced' I 100 percent agree with!
Standard Curvy Fork Springs paiste For Sale - SV's and SV related items 5 04-05-10 08:22 PM
0.85kg Curvy fork springs 7755matt Stuff Wanted 0 06-04-10 08:59 AM
Uprated fork springs for a curvy. streetos Stuff Wanted 0 06-03-06 09:33 PM
Will SK1 front fork springs fit a curvy? streetos SV Talk, Tuning & Tweaking 3 17-06-05 02:48 PM
