Old 29-01-11, 05:14 PM   #11
Mykey.M
Default Re: Seized pad pin
use heat. hot air gun if youi have one or a hair dryer if thats all you have. try and get some rust off spray, wurth make it. its very good stuff
Old 29-01-11, 06:40 PM   #12
Listen to the squid.
If you got them out by wiggling them with pliers then they weren't totally seized really were they?
Seeing the pistons are rust around the pad face, i think they're bad.
still took a good 10 minutes to loosen them after being soaked in release oil
Sid I was on about the fronts with the pads and pins
Old 29-01-11, 08:22 PM   #13
sv650ollie
heat them up with a hot air gun then wigle them . they should move then sand the pins copper slip them and bobs your uncle
Ollie
Old 29-01-11, 08:43 PM   #14
sv650ollie
oh sorry just read what mykey.m posted .
Ollie
How can I tell if my brakes are seized? arcdef Bikes - Talk & Issues 16 17-11-08 02:31 PM
Seized Screw TheShadow Bikes - Talk & Issues 7 03-07-08 12:17 PM
brakes seized......... a bit hovis Bikes - Talk & Issues 7 25-01-08 08:05 AM
seized bolt + more hovis Bikes - Talk & Issues 26 07-01-08 11:06 PM
Think i've seized it :-( Daimo SV Talk, Tuning & Tweaking 22 22-07-06 06:34 PM
