Old 09-03-11, 09:41 PM   #11
kaivalagi
Default Re: Is this Scotoiler set correctly
Could you fit the terminal between the guard and the fixing point to atleast hide some of it and then have the hose route as you've indicated in red behind the guard too?
Or as metalhead says, get some stick on clips...
Mark
Triumph and Suzuki owner
Old 10-03-11, 05:42 PM   #12
madmickyb
there ya go ....just make sure you degrease the swingarm before you stick them on !!
http://cgi.ebay.co.uk/METAL-CABLE-CL...item56416e3368
or you could use these ....
http://cgi.ebay.co.uk/25-16mm-x-16mm...item255e4486ab
i'd route the pipe as others have said under the swingarm .....
we use both these type of clips where i work (on hgv's) and as long as you degrease first you'l have no problems with them !!
hope this helps.....mick
Old 10-03-11, 06:37 PM   #13
Kenzie
Kenzie's Avatar
Even better, I keep these at work! Cool, get the bike Saturday so will take a look. Got my Fenda Extenda today as well. Anyone fitted one before?
Old 10-03-11, 07:01 PM   #14
kaivalagi
Did my fenda extenda yesterday....no screws just used a homebase kitchen/bathroom "advanced" sealant I already had. After giving the fender a good clean off the bike and then removing the sticky sponge strips from the extenda with a blade and white spirit I then applied the sealant on the extenda and fixed in place. I used masking tape to hold them together for 24 hours to be on the safe side, clamps would have been better but it turned out well anyway. I went for a bimble today and looking A okay and no screws!
Mark
Old 10-03-11, 08:00 PM   #15
garynortheast
garynortheast's Avatar
Nice one Mick - just bought some of the plastic ones. Thanks for the link.
Old 10-03-11, 08:41 PM   #16
Stonesie
Default Re: Is this Scotoiler fitted correctly?
When I fitted my fenda extenda I roughened it up a bit with sandpaper to give the sealant something to cling onto, tested to (Some) mph and it has not moved, only Tigerseal holding it on.
As for the Scottoiler the OP posted up, thats function over form but it should work just fine.
My TuToRo is routed under the swing arm and cant really be seen from the left of the bike, reservoir is on the right behind the rear brake master cylinder.
Old 10-03-11, 08:53 PM   #17
danf1234
That looks sh1te. I will take a piccy of mine when I can get at my bike. I did it with the bits in the kit and it looks a lot better than that. I have an L0, which is identical to a K7, 8 9 etc!
I used the stand lift bobbins for mine. You can't even see it!
HELP! Please. Clocks not working correctly. cbay SV Talk, Tuning & Tweaking 8 08-03-11 04:37 PM
Scotoiler Mr_Chin For Sale - Other Bikes and General biking items 3 12-02-11 08:41 AM
Crash.NET - Lorenzo airbag deployed correctly. NewsBot News 0 20-11-09 03:40 PM
gearbox not selecting gear correctly. DoubleD SV Talk, Tuning & Tweaking 5 30-08-06 02:22 PM
scotoiler cuffy Stuff Wanted 3 14-07-06 01:44 PM
