#11 |
#12 |
There you go, buy british and get air in your tyres
#13 |
My Daytona's got 'em too!
Nice one Triumph. In seriousness you'll get the knack of doing it with the standard valves. I remember when I started riding finding it a bit of a mission. |
#14 |
the S4 has them and the Superduke had one on the rear, I got the front one changed from a straight to an angled one at the tyre change, so now both are the same, does make life easier.
Cheers Mark.
#15 |
Good morning all.
Screw on 90 degree adaptors a supposed to be removed before riding. I've seen plenty of rubber valves that are seperating because of the weight of the angle valve, & centrifugal force. Use 'em & take 'em off afterwards. In order to replace the standard rubber valves with the 90 degree type as fitted to Triumphs you will need 11mm valves & not 8mm as shown. Also £26.99 a pair!! I'm doing them at £6 each when fitting tyres. Cheers. Last edited by Spanner Man; 30-03-11 at 07:01 AM. |
#16 |
Another +1 for tryumf
#17 |
Knob faced knobster
2011 Speed Triple 1050 |
#18 |
The Tuono has a metal valve so can't bend it like other bikes making it near on impossible to do.
#19 |
#20 | |
That looks like a bad case of Brewer's Droop ![]() |
Twinworks Caliper Adaptors | xXBADGERXx | Stuff Wanted | 0 | 05-02-10 07:04 PM |
ABBA stand adaptors | maviczap | For Sale - SV's and SV related items | 0 | 29-01-09 11:38 AM |
tyre valve just blow out | PJinUK | SV Talk, Tuning & Tweaking | 7 | 08-06-08 06:07 PM |
tyre Valve Change? | SV-net | Bikes - Talk & Issues | 11 | 08-04-08 05:14 PM |
Help!!! Tyre valve has gone awry... | Bluesteel | SV Talk, Tuning & Tweaking | 13 | 20-04-07 02:16 PM |
