Old 17-04-11, 10:59 PM   #11
mikerj
Default Re: sk3 rear shock
Originally Posted by frankie77 View Post
I'm lost...!! After checking other sites and forums there is a hole world of choice for another shock, from a gsxr.....636....zx10r is there a lot of difference or are they pretty much the same?
I'm 6'4 and 17st so does that make a difference?
Cheers people
Just be aware that most shocks from other bikes will require you to cut the toolbox/battery housing to make room for the external reservoir. The 06-07 ZX10R shock is the easiest swap for the pointy, it only requires removal of the plastic shield on the front of the battery box, but is a little longer than the original so will raise the rear a bit. The ZZR1400 shock will also fit in the same way and has a much stiffer spring fitted which might be more suitable for 17st and is the same length as standard.
636 rear shock drag Stuff Wanted 0 31-07-09 10:18 AM
Is my rear shock gone? chris_c201 SV Talk, Tuning & Tweaking 24 01-04-09 05:07 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
rear shock socommk23 Bikes - Talk & Issues 1 23-04-07 05:09 PM
what rear shock robertpog SV Talk, Tuning & Tweaking 2 16-02-05 03:38 PM
