Old 21-04-11, 08:30 AM   #11
daveyrach
Default Re: Car Horn on SV
So do more than 1 wire fit to some of the pins, i'm confused now :S
Old 21-04-11, 08:46 AM   #12
daveyrach
Is the SV battery earthed against the frame?
Old 21-04-11, 08:49 AM   #13
Nobbylad
Nobbylad's Avatar
Most folk use a relay to protect the wiring. But yes most horns are plug and play.
I've fitted a stebel nautillus compact to mine, but requires splitting the horn from the compressor, which isn't as difficult as it sounds.
Googlefu it, or look on SvRider.com on how to do this
No it doesn't...the Stebel Nautlius can be used without splitting it.
Old 21-04-11, 08:54 AM   #14
Maybe on a Pointy
Plus splitting it means that you've only got the weight of the horn to worry about and not the compressor, which I secured under the passenger seat
Old 21-04-11, 08:57 AM   #15
Geodude
Geodude's Avatar
Back of engine, right hand side, just to rear of clutch cover.
Old 21-04-11, 08:57 AM   #16
Relay connections
1. + connection from horn
2.- negative from horn
3. power from battery
4. power to horn
Then:-
Seperate wire from negative battery terminal direct to neg on horn
Old 21-04-11, 08:58 AM   #17
SoulKiss
SoulKiss's Avatar
If getting a cheap replacement horn, a relay is probably overkill.
My SV has a Nautilus on it without relay, my Z750 has a Nautilus with a relay - but then, that also has the stock horn AND a Magnum on it...
Old 21-04-11, 09:06 AM   #18
wyrdness
Originally Posted by warmshed View Post
Worth looking at the Stebel Magnum, they are a bit smaller and just as loud. Sounds like a Lorry!
+1 on the Stebel Magnum. I believe that Halfrauds sell them, or you can get one on line. You don't need a relay with the Magnum (I checked the manufacturers datasheet a couple of years ago to verify the power requirements), but some people prefer to fit one anyway. It's plenty loud enough, probably louder than most car horns and is the simplest solution as it just bolts on in place of the stock meeper. I fit one to every bike I buy.
Old 21-04-11, 09:10 AM   #19
punyXpress
punyXpress's Avatar
? Try putting a wanted ad on here ?
Looks like a few have fitted Stebels & they're hardly likely to go back.
Not sure if Berlin fitted one on his racer.
Now: Street Triple R
Old 21-04-11, 09:23 AM   #20
daveyrach
So can the Magnum be plugged straight into the OEM horn connector?
No Horn pin64 SV Talk, Tuning & Tweaking 1 19-07-09 12:11 PM
The horn Kinvig Stuff Wanted 6 18-08-08 12:15 PM
Got the Horn? metalmonkey Idle Banter 0 24-10-07 04:57 PM
Are you getting the Horn? DanDare Bikes - Talk & Issues 3 06-07-06 12:56 PM
Get the horn northwind SV Talk, Tuning & Tweaking 44 02-03-05 12:22 AM
