Old 27-07-11, 11:02 AM   #11
hardhat_harry
Default Re: Acceleration Flat spot
Had the same problem but in 5th, EBC Clutch springs sorted it dont understand why it seemed to be in just one gear though.
Old 27-07-11, 12:42 PM   #12
when was the last time the bike had an oil change?
Old 27-07-11, 02:44 PM   #13
Biker Biggles
Biker Biggles's Avatar
Do you mean flat spot or clutch slip?
A flat spot is when you open the throttle and the engine struggles to rev up because it wont deliver full power.
With clutch slip the engine will deliver power and the revs will increase but the road speed doesnt go up accordingly.
Old 27-07-11, 06:33 PM   #14
Webber
With mine the revs only go up slowly, only notice it sometimes but happens in all gears.
Old 27-07-11, 08:00 PM   #15
NTECUK
NTECUK's Avatar
have you done anything like put baffles in or adjusted the idle mixture and accidently pulled a vac hose off
Old 27-07-11, 09:17 PM   #16
fenjer
nope nope nope...
think it might be the clutch needing re-adjusted, me thinks the garage monkeys may have moved it to accommodate their monkey paws...
Will have a look on friday and see if it's still misbehaving.
Thanks guys!
flat spot? B16 N47H SV Talk, Tuning & Tweaking 5 06-03-10 09:11 AM
flat spot Wideboy SV Talk, Tuning & Tweaking 13 04-12-08 05:43 PM
flat spot? hovis Bikes - Talk & Issues 25 09-09-08 01:39 PM
No more flat spot toonyank SV Talk, Tuning & Tweaking 3 28-02-08 05:31 PM
Flat spot? yorkie_chris SV Talk, Tuning & Tweaking 25 20-07-07 05:24 PM
