Evel Knievel
got a a flat spot between 5.5k and 6k
balanced the carbs and that's smoothed it out loads and improved the pick up loads when coming out of it, but its still there soooo i thinking i have a air leak somewhere, can anyone give me some pointers to were the leak is likely to be to save me ar$ing about for ages tar |
#2 | |
Lol, some shocking replies there, i've the same thing in around 2nd gear, just under 5K rpm, she sticks and sticks and then shoots off, im thinking a rejetting would help
#5 | |
Evel Knievel
i got it in 4th to 6th but im guessing its in all gears just more noticeable in high gears |
There's usually a fair pick up in power at about 6k. Otherwise if it's a proper flat spot then check the position of the idle screws.
Gav are you still restricted?
#10 |
Have you had the carbs off or done anything else to it?
Flat spot when accelarating | JamoSV650s | SV Talk, Tuning & Tweaking | 8 | 28-03-09 01:51 PM |
flat spot? | hovis | Bikes - Talk & Issues | 25 | 09-09-08 01:39 PM |
No more flat spot | toonyank | SV Talk, Tuning & Tweaking | 3 | 28-02-08 05:31 PM |
Flat spot & alarm woes | jimw | SV Talk, Tuning & Tweaking | 8 | 24-08-07 01:48 PM |
Flat spot? | yorkie_chris | SV Talk, Tuning & Tweaking | 25 | 20-07-07 05:24 PM |
