Old 18-01-12, 08:49 AM   #11
Default Re: Sv 650 speedo drive cable needed for 2000 model
About £15 for the rotor.
I have never seen a broken sensor (£100+), but loads of rotors.
Only thing I've seen other than rotors, and wiring faults making both speed and tacho jump about, was when wire for sensor had been squashed in lockstop.
Old 18-01-12, 09:50 AM   #12
swifty09
Do the blades go in the sensor on the wheel not had my sv that long not to clued up on them cheers for the help Chris if so were can I buy one if I need it
Old 18-01-12, 09:53 AM   #13
There is a drum which runs within the sensor, and 4 tangs which are driven by the wheel, these end up snapping off.
Old 18-01-12, 11:50 AM   #14
I may have a drive rotor in the house if it is that is the case.
I'll check the state of mine at the weekend
Old 18-01-12, 02:40 PM   #15
swifty09
Ok just got home checked battery and negative was tightend more took her for a run was working at first went over a speed bump and it stopped and went over the second it start again ride all the way home was fine any ideas with the extra info
Old 18-01-12, 02:59 PM   #16
Check under green cover under right infill panel, 2 fat live wires go into it, give them a wiggle check they aren't loose.
If they aren't hanging loose then I'd pull front wheel off.
Old 23-01-12, 01:14 PM   #17
swifty09
Blades are broke 2 of them any ideas were I can get then from any one
Old 23-01-12, 01:25 PM   #18
Robinsons foundry.
Old 23-01-12, 01:26 PM   #19
Geodude
Geodude's Avatar
Try on here http://www.robinsonsfoundry.co.uk/ if its the rotor i think the part number is 34983-21E00
Old 23-01-12, 10:23 PM   #20
swifty09
Ended up getting one from a local breakers for £30 I'll try and be more carfull with this one thanks every one for your help
Pointy model Speedo drive basically Brand New £38 sv650k4 For Sale - SV's and SV related items 15 30-12-11 02:17 AM
k5 speedo drive same as 2000 boo86 SV Talk, Tuning & Tweaking 1 17-06-09 07:40 AM
Speedo Cable Needed tonyfarr Stuff Wanted 0 11-06-09 02:41 PM
has the sv650 99 speedo drive cable . elec hellraiser6661 Bikes - Talk & Issues 3 27-08-05 11:04 AM
