Old 03-03-12, 06:56 PM   #11
NTECUK
NTECUK's Avatar
Default Re: I can break anything in the world except my chain
Don't use a ratchet to loosen very tight fixing.Get a breaker bar.
Ratchets are not that strong and are likely
to slip round and then you smack your hand /skin ya knuckles
Old 03-03-12, 07:00 PM   #12
hongman
Wimp
I dont think the nuts are too tight, the problem is/was the sprocket carrier popping out as soon as I applied any force
Old 03-03-12, 07:05 PM   #13
NTECUK
NTECUK's Avatar
well you could get one of theses
http://www.machinemart.co.uk/shop/pr...-impact-wrench
We have the pro versions and they are brill for workshop uses.
http://www.easupplies.com/INGERSOLLR...t-p/pt11bc.htm
Old 03-03-12, 07:59 PM   #14
spider removal
start
if spider found goto next
acetylene + Lighter = burnt spider
if another spider found then goto start
if no more spiders then
you sheds gone!
Corrected mate
Old 03-03-12, 08:51 PM   #15
markc123
Argos will sell you an angle grinder for £18. Its a tool every man should own.
Or a plasma cutter will do the job should you feel spendy.
Old 03-03-12, 10:32 PM   #16
Dicky Ticker
Sod all that expense---- if you are not going to refit the chain after you take it off so undo the nut on the front sprocket and cut the chain with a hacksaw
Old 03-03-12, 10:59 PM   #17
DJ123
DJ123's Avatar
why not remove the sprocket carrier and secure it in a vice then?
BMW F800ST
Old 04-03-12, 11:55 AM   #18
hongman
Dont have a vice
Break up Warthog Thames Valley 62 22-12-09 07:23 PM
Chain + Sprockets, Front Break Lever and Pads - where from? Owenski SV Talk, Tuning & Tweaking 7 07-07-09 12:29 PM
how to break an sv davepreston Photos 12 03-07-09 10:57 AM
Front break not lighting break light? Baz SV Talk, Tuning & Tweaking 18 14-07-08 11:52 AM
