#11 |
Yes, you have to cut/solder the connections for a CBR R/R.
Not Grumpy, opinionated. |
#12 |
Thought that was the case
Does it need to be a connector or would spades be ok? Whats the level of the soldering as I aint the best at it
#13 |
enough to make a connection
![]() infact twisting the wires on makes the connection soldering just secures it Out of interest is the reg/rec problem as prevalent on pointies?
#14 |
I did the CBR mosfet reg on mine. Used the old connectors from the SV unit. If you're careful you'd be able to remove them with a small screwdriver without damaging them. I also soldered them on for good measure. also ran a ticker charging wire while I was at it. Less resistance means less loss and heat. There's a good write-up somewhere. I think I posted it on SV-rider...
#15 |
thanks everyone.
Going back to the main breakers up here on Monday to see if the one I did spot was the right one. Anyone else think of bikes that run Mosfet FH008's?
#16 |
#17 |
i'm doing the testing tomorrow to make sure its fubared.
#18 |
#19 | |
My soldering iron is crap TBH. Not able to persuade him to take other bit off the rat? ![]() Anyone know if ZX10R reg/recs are useable as I have an inkling there will be one at where I'm going
#20 |
see noob-sailbot's post http://forums.sv650.org/archive/index.php/t-146148.html
Heatstroke - Symptoms and treatment in dogs. | Samnooshka | Idle Banter | 3 | 04-07-09 11:58 AM |
Crash.NET - Stoner 'feels better', wary of symptoms. | NewsBot | News | 0 | 01-07-09 02:40 PM |
Obvious New Item of the Day | SoulKiss | Idle Banter | 7 | 20-01-09 06:33 PM |
Oh dear... Take these symptoms and... | northwind | SV Talk, Tuning & Tweaking | 13 | 14-07-08 10:37 AM |
Haggling if a bike has no obvious flaws... | Bear | Bikes - Talk & Issues | 64 | 21-11-07 09:04 AM |
