Old 27-03-12, 02:05 PM   #11
Default Re: SV1000 knocking at low revs.
Originally Posted by Red Herring View Post
Could it be something like a dodgy sensor. The ECU thinks the bike is cold and is keeping it in effect in "choke" mode making it very rich at low revs and not advancing the ignition at higher revs?
This.
Use the display code function and it might give you something to look at.
You can disconnect some of the sensors, (ignition off), and see if it tidies up the running - there are fall back settings in the ECU for failed sensors, disconnect them one at a time and see if things improve, some won't allow it to run at all, but that will be obvious, you won't damage anything by doing so.
More Knocking! Destruktor77 Bikes - Talk & Issues 7 20-10-11 04:03 PM
Knocking and Dropping! Lost@Home Bikes - Talk & Issues 0 10-03-10 01:12 PM
knocking forks. what causes this? robh539 SV Talk, Tuning & Tweaking 3 14-09-09 02:32 PM
Knocking Phaelok Bikes - Talk & Issues 6 28-12-08 05:51 PM
knocking??? guzz316 SV Talk, Tuning & Tweaking 9 18-09-08 12:51 PM
