Old 03-06-12, 08:35 PM   #11
curvysvboy
Default Re: curvy engine problem
Right ok, is it worth me taking the heads off, trying to turn it by hand and if fails againthen the cylinders? when you say big end what exactly do you mean, sorry im not the best mechanically minded person
Old 03-06-12, 08:39 PM   #12
Never seen that before.
Pull head covers, check cams are looking pointing in sensible direction and chain is tight.
Pull side covers, check nothing is fouling.
Do all this first before you have to replace head gaskets again.
Fookin ell not the best mechanically but you managed to replace the cylinders, much further than many ever go...
Old 03-06-12, 08:42 PM   #13
curvysvboy
ive had the cams back out along with the cam chain tensioners and the engine again locks after about half a turn in either direction.
its really bizarre, because it sounded perfect when it ran there was no knocks rattles or any suspicious sounds
Old 03-06-12, 08:43 PM   #14
rictus01
rictus01's Avatar
yeah you'll have the strip the heads off anyway, but try turning it over you've nothing to loose.
the bigend bearing is the other end of the conrod from the piston (the conrod has a smallend bearing holding the piston on, and a big end bearing attaching it to the crankshaft).
with the heads and the barrels removed, you should be able to give the piston a wiggle and feel for freeplay, if there is any, it shows the bigend is fubar'd
Old 03-06-12, 08:44 PM   #15
rictus01
rictus01's Avatar
just a thought, is the rotor on straight ?
Old 03-06-12, 08:45 PM   #16
curvysvboy
Sorry what do you mean rotor? And again im not sure! and will have a check
Old 03-06-12, 08:47 PM   #17
rictus01
rictus01's Avatar
the alternator side (sitting on the bike LH side), has a rotor on the end of the crank, if this was to come off it could lock the crank, not a usual issue, but worth a look.
Old 03-06-12, 08:52 PM   #18
curvysvboy
Right I will check that first then start stripping the heads etc. Would you reccomend taking the engine out completely and doing it on a bench? Any key points or parts to pay special attention to?
Old 03-06-12, 08:55 PM   #19
You should be able to to find out what is wrong with it in frame.
As normal there is slight angular play in the conrod and slight side clearance too. However if you can feel any radial play like up and down movement in the rod then the big end's knackered.
Old 03-06-12, 08:59 PM   #20
curvysvboy
Right ok, what if ive stripped the heads etc off and big end bearing seems fine but engine still locks, what would your next venture be?
Engine parts and a complete engine for sale as well as other curvy spares EssexDave For Sale - SV's and SV related items 10 23-01-12 08:41 AM
engine problem Richie07 SV Talk, Tuning & Tweaking 2 21-12-11 11:39 PM
Engine problem? bigchris SV Talk, Tuning & Tweaking 5 21-04-11 01:18 PM
engine problem davyblue SV Talk, Tuning & Tweaking 1 11-03-08 09:06 PM
Naked curvy with engine problem -- anyone fancy a project Paul M SV Ecosse 10 01-08-07 09:14 PM
