Old 02-07-12, 04:44 PM   #11
Glen650
Default Re: Removing damper rod bolt - how?
Ye always good saving a bit of cash , Just a little tip instead of using a broom handle try a 3/4" or 2 cm square piece of wood you will find all four corners will fit inside the top of the damper rod just tap it with a mallet and you will find theres less chance of it spinning. thanks again guys cheers Glen
Removing damper rod bolt? 85jas SV Talk, Tuning & Tweaking 18 01-04-12 09:58 PM
Removing Main Engine Bolt toby_smith SV Talk, Tuning & Tweaking 5 21-04-10 09:35 PM
Fork Damper Bolt squirrel_hunter SV Talk, Tuning & Tweaking 7 09-09-07 12:45 AM
SV650s 1999 Curvy Damper Bolt (For Forks) Wanted cudd Stuff Wanted 2 26-08-07 08:23 PM
Damper Bolt For Fork, sv650s 1999 curvy cudd SV Talk, Tuning & Tweaking 7 24-08-07 11:03 PM
