Guildford Massive For the Guildford Guys N Girls.
Old 17-08-12, 08:58 PM   #11
DJ123
DJ123's Avatar
Default Re: wanted-Lock Nut removal tool for Swing Arm
You don't cut the whole socket, simply cut the prongs into/out of it. Sockets are strong enough to take it and will have the strength to undo the initial tightness of the nut
BMW F800ST
Old 17-08-12, 09:02 PM   #12
Thunderace
Yes I understand the concept, and i'm telling you when those sockets were drop forged, they weren't designed to be fiddled with, cut it, try it, first turn it'll break!
Old 17-08-12, 09:06 PM   #13
DJ123
DJ123's Avatar
i hate to say it, but it is recommended in the Haynes Manual!!!! It's only 4mm off the end and they are chromed too so should be stronger than normal. Will be wearing some padded gloves when first trying to turn it
BMW F800ST
Old 17-08-12, 09:08 PM   #14
Thunderace
Good Luck! I'll owe you a pint if it works!
Old 17-08-12, 09:11 PM   #15
muzikill
muzikill's Avatar
Id buy one off ebay. I bought the engine removal ones and they were fine.
Old 17-08-12, 09:17 PM   #16
DJ123
DJ123's Avatar
I'll have a pint of Vodka
I'm tempted to, however my aim is to get it done this weekend. If it's not possible i'll order one. I'm reluctant to as i'll never use it again after today
BMW F800ST
Old 17-08-12, 09:21 PM   #17
Thunderace
Try posting in Bike Issues or similar there has to be another member with one!
Also chrome doesn't make sockets stronger, it's there to help prevent tarnishing & corrosion, I've got and old set of impact drivers you could try it with but I still think cutting into even them will make them less than useless!
Old 17-08-12, 09:22 PM   #18
Got a curvy one, if that's the same?
Old 17-08-12, 09:25 PM   #19
DJ123
DJ123's Avatar
Mav, what's the size of the socket. Maybe worth a try!
BMW F800ST
Old 17-08-12, 09:35 PM   #20
muzikill
muzikill's Avatar
Ahh. I see you have a k3. Im after one of those tools. If you end up getting one for once only ill be interested taking it off your hands.
Swing arm removal with abba stand? DavieSV SV Talk, Tuning & Tweaking 5 12-06-09 10:16 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
tool for removing swing arm and engine fat_brstd Stuff Wanted 6 08-05-07 12:00 PM
Tool for swing arm removal? Sir Trev SV Talk, Tuning & Tweaking 5 27-06-05 04:18 PM
Fuel cap lock removal Sudoxe SV Talk, Tuning & Tweaking 4 10-04-05 03:34 PM
