Guildford Massive For the Guildford Guys N Girls.
Old 19-08-12, 09:11 PM   #11
Thunderace
Default Re: Argghh. Brakes!
Grease the lever pivot and examine the pivot bolt for damage, and also the stub end of the lever for wear where it contacts the master cylinder piston.
The piston makes a linear movement, however the lever rotates about the pivot bolt meaning the stub makes a wiping movement across the end of the piston, commonly wearing flats on it.
As you pull the lever the flats drag across the piston in a notchy manner, not unlike that you're describing.
If the damage isn't too great you can effect a fix by carefully reprofiling the lever to a neat smooth curve - don't take too much material off or the lever can become loose at rest.
Its fixed, someone had greased it and it got all gobbed up with sh*t, removal, fairy liquid, re-fit, boom working brakes!
Old 20-08-12, 06:30 AM   #12
Fallout
Fallout's Avatar
Yeah, the grease was the problem itself. It has been greased where the lever slides around in the housing and was causing it to stick because of the road dirt the grease had picked up. I think a bit of WD40 in there now and then will do the job.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 20-08-12, 06:34 AM   #13
Viney
And here endeth the lesson. Start with the simple stuff first
Sent from my Sony Xperia S using Tapatalk2
Old 20-08-12, 08:39 AM   #14
Mark_h
Mark_h's Avatar
Maybe time to get the Ace to come see if he can sort my scooter brakes then. Simply seized piston, glazed disc and underwhelming ability of something that would pass as a rear brake set-up on a real bike trying to shift 12 year old fluid. Oh and every nut, bolt and screw corroded into place with each nut, bolt and screw head torsional stiffness being modelled on the finest ripe brie on a warm summer day.
Having digested this thread I've tried covering the disk in WD40 and the tyre in washing up liquid but if anything it's made it all slightly worse but very bubbly. Next I'll send the plastics off to the local chipshop for a respray, run some injector cleaner through the indicator flasher and obviously change the reg/rec.
Luckily the rear brake is magnificent!
Equally lucky is the fact that it rarely goes quick enough to need significant braking.
Minister for Sustainability
Old 20-08-12, 09:15 AM   #15
Jammy
Was going to say mark, you could probably drag your feet and get adequate braking force
Old 20-08-12, 09:19 AM   #16
Mark_h
Mark_h's Avatar
As opposed to the "chuck it sideways at the tarmac" method?
It's amazing how much no brakes, no power and questionable suspension improves your forward planning. I think one ride in 10 should be on something like my mighty Epicuro just to keep your skills sharp. Then when you get on something with much better (or in some cases marginally better) brakes, power and suspension you can apply your improved planning skills more productively.
Old 20-08-12, 11:55 AM   #17
Spank86
But if you plan ahead you miss all the fun.
Old 20-08-12, 01:18 PM   #18
Littlepeahead
Littlepeahead's Avatar
That's a bit unfair Viney, Fallout is a bit dopey at times but calling him a simpleton is going too far.
Brakes FlyinCustard SV Talk, Tuning & Tweaking 35 08-05-09 11:36 AM
Better brakes rob13 SV Talk, Tuning & Tweaking 12 21-09-07 04:17 PM
Brakes Jon Digital Bikes - Talk & Issues 14 15-07-06 01:12 PM
Brakes ! stewboy SV Talk, Tuning & Tweaking 3 19-12-05 04:55 PM
No Brakes The Mass SV Talk, Tuning & Tweaking 13 16-11-05 11:01 AM
