Old 19-10-12, 04:48 PM   #11
zunkus
Default Re: Bike Won't Start - HELP
Have to go now... better half's waiting
Good luck mate, but it looks like a blown fuse to me.
Old 19-10-12, 05:11 PM   #12
TCochrane
Right, just checked those fuses, one of the 30A fuses was blown. Thanks a lot for your help
Just need to find some way of getting a 30A fuse.. haha
Old 19-10-12, 05:12 PM   #13
It's under the rider's seat. There at first appear to be two fuses, but one is the spare, pull them both out and you'll see that one has two metal receptacles that the blades of the fuse engage with, and one is just a plastic holder.
Old 19-10-12, 05:14 PM   #14
TCochrane
Wait - so one is a spare?? You're saying that I could swap the other one with the blown one and it'd work?
Old 19-10-12, 05:24 PM   #15
Default Re: Pointy won't start - no electrics.
One fuse is in a dummy holder not connected to anything - it's a spare.
Whether replacing the fuse will fix the problem depends on why it blew, if the fault with the electrical system is still present then the replacement will pop too. Which is a good thing. Until you try you'll never know.
Old 19-10-12, 05:25 PM   #16
TCochrane
Put the spare fuse in and it works again - thanks all
Old 19-10-12, 07:12 PM   #17
zunkus
Glad to be of some help mate. Cheers!!!!
Old 19-10-12, 08:42 PM   #18
aaron020873
If it was all working fine before then hopefully it will of just blown because of the bare wire that touched the frame.
Old 21-10-12, 09:43 PM   #19
phil24_7
Just make sure you replace the spare!
Must be summer, Pointy wouldn't start. munkygunn182 SV Talk, Tuning & Tweaking 10 27-03-12 05:18 PM
Pointy won't start? Chec error? RingDing SV Talk, Tuning & Tweaking 2 21-07-09 08:59 PM
Pointy electrics problems Dave20046 SV Talk, Tuning & Tweaking 19 15-07-09 02:20 PM
Pointy won't start! trinyquist SV Talk, Tuning & Tweaking 19 15-10-08 10:35 PM
Please Help Pointy woes - won't start. RGV250ads SV Talk, Tuning & Tweaking 17 20-05-08 04:28 PM
