#11 |
Definitely first gear. I passed mine a couple months ago. Slip the clutch, rear brake and make sure you look where you want to be.
#12 |
Slipping the clutch +1. Look where you go +1. Key to not feeling tempted to put your foot down when going slow is to keep the revs up and slip the clutch to maintain the correct speed during the manuever. Revving high stabilises the bike (not too high
#13 |
first gear and good clutch control
#14 |
+1 to clutch control. Makes me glad I did mine on a knackered old cb500 which felt a lot less torquey than the sv in first. Good luck!
#15 |
So how did you get on?
#16 |
First gear
fair amount of revs control power with the clutch ( always slip clutch when doing slow maneuvers ) control speed with rear brake ( keep foot resting on brake ) |
Gear Shift Rod bent - Gear Changing problem | Thaleshwar | SV Talk, Tuning & Tweaking | 13 | 05-06-10 06:28 PM |
Gear change problem-can't get past 2nd gear | muzikill | SV Talk, Tuning & Tweaking | 8 | 14-03-10 10:10 PM |
Gear change problem-can't get past 2nd gear | muzikill | SV Ecosse | 8 | 13-09-07 07:45 PM |
