Old 05-12-12, 09:55 AM   #11
Default Re: Alternative to jacking up a pointy for a shock swap?
Originally Posted by Wildkid View Post
Yeah I've got a 2 tonne trolley jack ? Will that be okay?
Yes.
Make sure the area you're lifting on is flat and firm, put a rubber band around the front brake lever, don't lift it too far, be sensible when it's lifted and make sure you choose and pack the area of the motor you lift on carefully - as far back and as far to the right as possible is best, i.e. as far away from the stand as possible. When it's lifted it will be perfectly stable if you do it properly, but obviously you'll need to loosen/tighten all the fasteners while it's on it's wheels.
Old 05-12-12, 10:01 AM   #12
-Ralph-
Your trolley jack will be fine. Don't jack dead centre and try to balance the bike upright, you will drop it. It should still be leaning on the sidestand with the jack off centre on the opposite side, so you have a tripod, between side stand, front wheel, and jack.
Old 05-12-12, 10:01 AM   #13
-Ralph-
Sid beat me to it.
Old 05-12-12, 01:43 PM   #14
Wildkid
Cheers for the advice people, im guna see if i have a ladder as that might be a better option for me, if not im just going to use axle stands and a trolley jack
curvy alternative rear wheel swap curiosity. MRedhead SV Talk, Tuning & Tweaking 14 03-11-11 04:18 PM
Alternative rear shock for a curvy? stew SV Talk, Tuning & Tweaking 15 10-04-10 09:10 PM
Alternative shock for SV650 eval k-neil SV Talk, Tuning & Tweaking 21 18-06-09 09:21 PM
Shock Swap Help jvdairlie SV Talk, Tuning & Tweaking 5 21-11-06 02:22 AM
Fitting Alternative Shock Jimmy2Feet SV Talk, Tuning & Tweaking 2 27-10-06 02:13 PM
