Old 31-01-13, 07:54 AM   #11
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Changing dashboard bulbs? anyone done it?
I'm guessing the LEDs used are probably the SMD ones, I've used them quite a lot as I used to do colour conversions on car switches.
If you're going to do it yourself get a soldering iron with a fine tip and some tweezers because they're bloody small!
Here's one pictured on a 1p coin to give you an idea of size
And that's not even the smallest you can get!
2011 Speed Triple 1050
Old 01-02-13, 12:42 PM   #12
CodeJACK
I swapped mine for blue last year and thought it was really easy to do.
I have a little soldering experience so if your willing to give it a go, maybe test on something old first.
A desolder pump is essential as the existing LEDs are fitted with a large amount of solder. So heat one side of each LED and remove one side of solder on each first.
Then start on the second side of each and prise them off as you heat.
Check my flickr in the sig for some pix.
CodeJACK is offline   Reply With Quote
Changing speedo bulbs on Curvy? blackwatch_uk SV Talk, Tuning & Tweaking 20 11-11-16 11:22 PM
Changing dash bulbs? dazzaboy Bikes - Talk & Issues 17 05-10-12 09:29 PM
Changing indicators - LEDs or bulbs? HoL SV Talk, Tuning & Tweaking 8 16-10-11 05:34 PM
Changing Speedo Bulbs? dazzaboy SV Talk, Tuning & Tweaking 4 10-03-11 08:06 AM
Changing Light Bulbs... Drew Bikes - Talk & Issues 8 25-01-08 10:32 AM
