Old 14-05-13, 10:26 PM   #11
LewSpeight
LewSpeight's Avatar
Default Re: sv650x ecu
Originally Posted by otaylor38 View Post
Im confused?
There isnt an ecu on a 2000 curvy as it has carbs. Carbed engines use a CDI unit which merely controls the spark. You cant restrict a carbed bike with a cdi unit.
You need the carb sliders as alex above says to restrict a 2000 sv. They just fit between the carb and the manifold on the engine in order to restrict the amount of fuel/air that can get through.
If it was a 2003 onwards sv, then it would be fuel injected and then it would be possible to restrict via an ecu which is mapped to 33bhp.
You have just revived my sanity.
Old 15-05-13, 07:09 AM   #12
otaylor38
Glad to hear it mate. Now somebody just needs to revive mine. This might be slightly more difficult...
Old 15-05-13, 09:15 AM   #13
LewSpeight
LewSpeight's Avatar
Default sv650x ecu
Just ride your bike, JOB DONE
Sent from that magical device in my pocket.
Old 15-05-13, 11:05 AM   #14
phil24_7
So to recap. Either the OP has a 2000 bike and needs to remove the throttle stop and washers, or he has an 03 or newer bike and either needs to remove similar items or swap his ECU depending on which way his has been restricted!
Reg / Rec for sv650x ('99) Terah Stuff Wanted 2 03-07-11 07:55 PM
SV650X For Sale Capt.Pimpship For Sale - SV's and SV related items 0 03-05-11 04:22 PM
What does the X mean in SV650X wow Bikes - Talk & Issues 4 04-03-08 12:55 PM
Cheap 99 SV650X instigator For Sale - SV's and SV related items 0 15-01-07 01:31 AM
SV650X 99 Curvy cottonbud Stuff Wanted 0 04-10-06 07:35 PM
