Old 17-10-13, 09:37 AM   #11
Mauler
Mauler's Avatar
Default Re: Oil smell but no leaks!
I'm still confused by this crash bung oil event. If its the middle mount (most likely place for them based on mine and others I've seen) then there is no good reason for oil to be behind that...
This. Bungs mounted this way, I think, are not near any joins or openings in the engine casing and so shouldn't have oil anywhere near them. It sounds like the engine casing is cracked or the oil is making it's way down onto the bar/bungs on the outside the casing from a leak higher up?
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
-Thorin Oakenshield, The Hobbit
Mauler is offline   Reply With Quote
Old 17-10-13, 09:31 PM   #12
sopeluk
That was the case, but after replacing the bolt with the OEM one, it stopped leaking. Engine case is dry as sand..
Old 18-10-13, 08:45 AM   #13
jambo
jambo's Avatar
Perhaps they'd been recently installed and a copious amount of oil had been used to lubricate them during installation? I can think of very little else that would fit the symptoms.
Jambo
Common oil leaks? Pointy. Phil 1 SV Talk, Tuning & Tweaking 6 03-03-13 06:45 PM
Airline connector leaks? Bibio Bikes - Talk & Issues 8 02-11-12 05:28 PM
Smell of fuel but no sign of leaks N77 SV Talk, Tuning & Tweaking 13 04-07-12 09:20 PM
My disconnected tank sometimes leaks DarrenSV650S SV Talk, Tuning & Tweaking 6 07-02-08 09:29 PM
Oil leaks from the engine muffles Bikes - Talk & Issues 5 23-12-07 10:44 AM
