Old 15-02-14, 04:26 PM   #11
Murley.
Default Re: Feels like chugging
Even with the carb heaters working, icing does still occur when using cheap fuel. Another reason to use the premium stuff.
Old 15-02-14, 04:30 PM   #12
embee
embee's Avatar
Fairly classic symptoms of sticking choke plunger.
Old 15-02-14, 07:08 PM   #13
Alexander94
Ok, i'm not very good with wiring so it's not the sort of thing i'd want to risk, knowing my luck I'd break something ^^ i'll see if riding it for a while warms up the whole area up and see of that makes a difference. I'll also try checking my fuel lines, pump, spark plugs and all that stuff.
Thanks
Old 15-02-14, 07:08 PM   #14
Alexander94
I'll check the choke plunger too, thanks
Old 15-02-14, 09:52 PM   #15
Biker Biggles
Biker Biggles's Avatar
Default Re: Curvy running poorly.
Its been a bit wet recently.Front plug hole got water in it?Fuel got water in it?
Choke plungers should be a regular service item to prevent trouble.
Old 15-02-14, 10:46 PM   #16
Alexander94
I don't know if there's water in the plug hole, i haven't had the time to check today, i'll be doing it tomorrow. There shouldn't be water in the fuel though. I filled the tank from almost empty a couple of days ago and i'm very careful about not letting water get into the tank
Old 16-02-14, 02:01 PM   #17
wideguy
Almost empty tanks in winter invite condensation from humid air and temperature changes. Better to let it sit fully fueled.
Old 16-02-14, 07:07 PM   #18
Alexander94
It was only sitting overnight with about 4L in.
I rode it today and it felt absolutely fine which is good. It's confusing because it happened all of a sudden and it went just as quickly... As long as it's running alright I'm happy though! Thanks for your input, everyone! I love how helpful everyone is here!
Pointy running poorly. sKiTz-0 SV Talk, Tuning & Tweaking 17 19-04-19 06:49 AM
Curvy running poorly. craig dow SV Talk, Tuning & Tweaking 8 02-10-12 08:55 PM
Curvy running poorly. craig dow SV Talk, Tuning & Tweaking 7 31-08-12 09:26 PM
Curvy running poorly. live steam SV Talk, Tuning & Tweaking 12 20-01-12 10:55 AM
running poorly matt_rufus SV Talk, Tuning & Tweaking 8 15-04-09 08:25 PM
